building a small butane regulater
Here are a couple of valves.
The regulator one is geared towards gas cylinders available in the UK, you would need to make it to fit whatever canisters you use. The other valve is a demand valve, just like for scuba diving, it allows gas through only when the engine requires it, when the engine stops, it turns the gas flow off.
I have just imported about a dozen of the diaphragms and valves from the US for some jobs I have to finish off, but they are readily available on eblag for less than 10 bucks the pair, if you search about.
View attachment Gas Valve And Regulator.pdf
I took a gas furance valve apart this morning and there was abig enough gasket in it that i beleive will work for my diaphrams. a lot testing I will have to do. Dale
Hi John the material I have is neopreme . there is two differant thickness . One is really thin the other about 3 time as thick .Thanks for the comment .Dale
