Brass castings freezing short.
Humph7ey
th
Hi Guys, long time. Since my last project making oil pumps for a vintage Austin, I am attempting to make the elliptical bezels for Hobson Telegage fuel gauges.
I am using Mansbond oil tempered sand and the bezel sections are 6.5mm wide 90deg triangular section 85mm high and 45mm wide. I have made a mould for four of these.
There are four 2.5mm dia vents to the rear of each one. The sprue is 30mm dia arranged centrally with 10mm feeders to each part.
I tried doing four at once then when that did not work, tried two which also failed.
I think the brass is hot enough as a steel stirrer rod smokes when exposed to the air.
Is it possibly just a temperature thing, or do I need larger risers?
With that thin a cross section I can see why you have troubles. If its freezing, its simply shedding too much heat before it fills the form, and the only fix for that is more/fatter risers and feeds. Larger mass of molten metal as close as possible behind the feed. If you had one fat riser feeding a circle around the part say 3/4" square with a gate every 30-45 degrees would be my first guess. Sand isnt the best medium for this thin stuff, most likely it was die cast originally.
I am hiring a laser temperature gun over the weekend and will get the metal as hot as possible and try your suggestion.
The originals were pressed sheet and I tried that with no success either.
The next think is to get them cnc milled. A pantograph engraver might work also.
I might try leaving the sand in the sun.
I agree- the metal is losing too much heat to the sand and is freezing up before it reaches the extremities of the mold.
Additional ideas:
1) Use an elevated sprue to get the metal's hydrostatic pressure up. ie- get a coffee can, cut out top and bottom. Fill with sand. Cut a sprue in the center and position it over the sprue of the main mold. Extra sprue height == higher pressure.
2) Pre-heat the sand. In industry they probably use ovens, but a blow torch used on the sand before you close up might take the chill off and keep the metal fluid longer, as you say - just leaving it in the sun would be better than nothing.
Try cutting a circular runner all the way around the part about a half inch deep then cut in multiple gates to the part. If that doesnt work then switch to a bronzer style flask. I would love to see some pictures...
Well, that did not work either. Would it be better to try the lost wax process? I have no idea how that works, but is the mould heated and the molten brass poured with the mould still hot? I have a brass French clock with fine casting on it with no sign of sprue marks.
Lost wax is all ways my first choice for ornimental thin castings.
An open face mold. Less mold in contact with the molten bronze so it will flow better.
I am giving up on sand casting. There is only so many times I can make up the mould only to see it wasted again. I learned a lot.
Next step will be lost wax process. Sorry about the pics, but there is not much to see anyway. Thanks for the help.
