As I promised in Question and Answers section here are pics of my boring head.
The little 4-40 screw goes through the set screw hole for the horizontal boring bar and sits in a counter sunk hole to screw the brass 1/4-20 nut to the slide. The brass nut sits in the pocket that was milled out with a .125 end mill. I will lock tight the screw in after I give it a good de-greasing.
Here it is assembled.
I cut the radii on the slide with ball nose end mills. Man they sure make a lot of needled swarf. Finally used my shop vac to suck them up as I was milling and that helped a lot
There are a few goofs on it but none that will effect its operation. The rear vertical boring bar hole was almost drilled in the wrong spot, but I caught it before I couldn't move it. That is why there is a small hole next to it. Its not drilled to depth.
I also made 3 MT 2 shanks before I got one right. The threads were not concentric with the shank as I was tuning it between centers. Then the light went off in my head and said to myself self, mount the finished taper in the head stock then cut the threads. All was well then.
I haven't made the setting dial yet as I need to set up some sort of dividing mechanism. If I don't have a 25 tooth gear maybe use Turbocad to print up a circle with 25 marks on it and glue it to some plywood and mount to the rear of my spindle with a pointer.
Well thanks for looking and all comments are welcome.
Ron
