- Apr 3, 2017
- 222
- 120
Hi Everyone,
I have got myself stuck on my BollAero build and could really use a hand. I was wondering if there are any 2stroke compression-iginition experts out there that might be able to give me some tips. this is my second IC engine after a Webster and it seems these little puppies are less forgiving. The build is partially documented here A pair of Boll Aero 18s
Fundamentally I am wondering whether converting the Chris Boll plans (BollAero 1.8 Gallery) from Imperial to Metric using the 'that's close enough' approach (particularly on drill sizes and fasteners) is the root of all my ills.
In short, the engine seems to fire up nicely if i squirt primer into the engine exhaust port / under the piston on the intake. It will start and rev nicely for 3-4 seconds and then stop. No matter how much i play with the needle on the carburettor the engine does not keep running, When i look at the intake, it seems to be spitting out of it quite a bit but It's hard to tell since there is fuel flying everywhere from squirting in the primer.
I have tested the carb on my Webster and it runs (though not that great to be honest vs. a vapour carb). Still, it seems to work.
The thoughts i have are:
Any input would be greatly appreciated. Thanks, Patrick
- There may be insufficient crank case vacum to suck in fuel when the inlet port opens. I am tracking down and fixing any crankcase leaks i can find (might add some gaskets).
- My round-up/round-down to the nearest drill size might have screwed up the timing of the engine beyond repair. This is what i'm looking to rule out.
