One thing that has not been mentioned, is NEVER ADD WATER TO A BOILER THAT HAS RUN DRY, extinguish the fire and wait until the boiler is cold. You should then retest Hydrostatically..."
Personally, I would pull the fire altogether, but the point is exactly the same.
Not a good situation to be in regardless!
That situation would result from violating the first three rules of operating a boiler.
You will rarely see them written down formally, but everyone abides by them.
You ready, here they are, pay attention,
1. Keep WATER in the boiler.
2. Keep water IN the boiler.
3. KEEP water in the boiler.
I am not kidding.
Additionally, ( and even more seriously) you should have at a MINIMUM two ways to GET water in a boiler. One should be a hand pump. ( I'm talking about the boilers the average ME will run here.)
My boat has three, BIG Hand pump, engine driven feed pump, and injector, all on separate circuits with separate checks and separate stop valves.
Don't forget plumb a stop valve between the boiler and the check. Checks fail!
Sub section rules for the above three are listed but not limited to the following:
Make sure your gauge glass is clean and it can be blown down and/or isolated, and you know how to blow it down.
Make sure you have trycocks for WHEN the gauge glass breaks ( it will ). know how to use them.
Put a Guard on the gauge glass so when it breaks you are not wearing it in your forehead.
I make no claims to my good looks, but I have grown rather attached to my face and would like it to stay there.
Make sure your lowest gauge cock and the bottom of your glass are suitably above the crown sheet/drum tube connections. How much depends on the boiler design....I can't help you there.
Make sure you have the tools to draw a fire if things go catiwampus on you. If you burn wood or coal, that would be an appropriate shovel. In a boat it's over the side. In other situations, any safe place other than the fire box.
Running a boiler is not a day at the beach. Dress appropriately. Wear jeans and full sleeve shirt and boots with socks, not flip flops. A fool runs a boiler bare handed. Gauntlet gloves are a must. OK miniature boiler valves may restrict your glove wear...make sure the handles are thermally isolated then. Safety glasses would not be amiss.
ANTICIPATE! This is important and can be the most stressful and difficult part for an operator to learn. Think about where you want the boiler conditions to be 10 minutes from now. Look at where the pressure is going, not necessarily what the gauge is reading right now ( is it rising or falling and how fast). Firetube boilers react to firing rate much slower than watertube boilers generally. Learn how your boiler behaves. Every one is a little differant.
Think ahead and soon you will be letting it run, instead of making it run......there's a difference and it takes practice and experience to learn it.
Have fun and be safe.
