Shipdisturber
- Dec 7, 2016
- 131
- 41
Right up front my apologies to Jann Ridder, it was his plan I loosely followed then promptly butchered. First off my machining skills are flawed at best and my patience factor has a lot to be desired. This little motor should be held together by good machining and Loctite 603, I soldered everything together because most of my fits weren't good. The best part is the little crankshaft because believe it or don't that thing spun beautifully. The rest of this little project will be in the scrap bin. I may save the little crank for another day. The part of the crankshaft build that was supposed to be removed I soldered in place and made the crank around it, then I cut the scrap metal out of the centre. This is the place for anyone who needs a holier than thou fix because this is not how you guys do these things. I attached pictures because every picture tells a story.
