- Feb 18, 2013
- 409
- 232
what a lovely deep red. nothing wrong with a plain aluminium finish - but the colour certainly lifts it. does it get stored in an oily rag, or on a purpose made mounting?Despite still being a non-runner, I decided to anodise the cylinder and spinner anyway.
Its surprising just how small this engine is when compared to the Clanford Clan.
All my engines are mounted and on display in a cabinetwhat a lovely deep red. nothing wrong with a plain aluminium finish - but the colour certainly lifts it. does it get stored in an oily rag, or on a purpose made mounting?
Hi again Ken,If you make the Nano carb exactly to the drawings, the carb bore of 2.4mm diameter has an area of 4.524 sq mm. But the 2.2mm dia jet projects into the bore some 0.4mm beyond the centre and this reduces the choke area to 1.356 sq mm. [This neglects the reduction in area caused by the needle itsself]. If the jet does not project this much into the carb bore, the choke area will be far too big to allow the engine to draw fuel. By contrast your Clanford Clan has a carb area, [neglecting the reduction caused by the needle], of 1.53mm for an engine almost 2.5 times the displacement. Even if built to drawing, unless the Nano is capable of much higher rpm than the Clan, the carb area is much too large.
Ken
Please need the complete project!
I didn't get it on Nexus!
Been a while since I visited. Just want to say don't give up yet. I've made 7 of these now and most of them have been a real chore to find the running settings and get them started. I actually put 3 of them aside because I got so fed up with not getting any response at all. Pulled them out a month later and got them all started and running. Don't know what the difference was.
Yesterday I made some spring starters for them as per the Nano drawings. What a difference - they are now so easy to start - it's a real
Hi Dave
You made 7???!!!! Wow!
I must say the video shows a sweet motor! Well done!
I am also encouraged by the fact you are using equal mix of fuel too.
After a break since my last post I did make yet another piston and refined the fit but still no luck even using my'safe' electric starter.
I will revisit it but it is doing my head in. Not sure if its my build quality or what but hey ho.
Thanks for posting
Rich
Its funny how often a project ends up being more than just making the parts. Its all the things you have to make to achieve it!
So, I made my cutter, 4 blade as opposed to the authors 3 blade, from En24T and hardened and tempered it. It would be nice if it was a 2o tooth or so but there are limits to my abilities!!
Also I realised I would need to make some fixtures to hold the cylinder for the machining as I wasn't intending in following the author method of milling in the lathe.
So, a threaded bush to hold the cylinder in a rotary table and an angle jig for the drilling of the transfer ports.
What you have made is commercially available and is known as a " needle eye" lap and in the real world they are the usual way to lap small bores. The halves are normally just forced apart with special pliers.Today I drilled the transfer ports using a jig at 45 deg. I confess I eyeballed the position although the offset distance was dialled in using a pointer from the datum edge.
Next is lapping which I normally do with a short split lap but I didn't have a suitable one this small so decided to make a different design.
Basically, two cylindrical rods milled to half diameter, soft soldered back and turned to the finished diameter for the job.
Centres and ferrules also made for keeping it together when separated by de-soldering and cleaning off the solder from the faces.
In use, one end is held in the chuck and the other in a dead centre, the ferrules keeping it together.
Paper shims are added to increase the diameter and being a long lap gives better control of diameter. Or the theory says!
Thanks Ken,What you have made is commercially available and is known as a " needle eye" lap and in the real world they are the usual way to lap small bores. The halves are normally just forced apart with special pliers.
Ken
hola soy Rubén me puedes mandar los planos del motorAfter a reasonable success (at least a running engine) of the Clanford Clan, I decided that self flagellation was the key to getting through Covid19 crisis.
So , I have started to tackle the Nano 0.1 cc engine by Richard Gordon.
I am gobsmacked by the quality and intricacy of design produced by such a young enthusiast at the time.
I know this is going to be a demanding project with some tricky thread turning.
My equipment is probably as basic as the author had but my skills are less so.
Sin embargo, primero fue el cigüeñal y este se giró de EN24T, que es bastante horrible para girar en mi torno, pero con cuidado y un poco de pulido para terminar, salió bastante bien.
El pasador del cigüeñal se giró por el método habitual de un casquillo dividido con un orificio central descentrado de 2,5 mm.
Rubenhola soy Rubén me puedes mandar los planos del motor
Hola muchas gracias
