Atkinson Differential Engine
Help Support HMEM:
Charlie
New Member
Redcliffe Qld Australia
hi my name is Charlie and I'm building the differential engine. To increase the compression ratio I will make the piston a bit bigger but on the "working" piston I will give the piston a flat crown leaving just 1mm clearance to the opposing one but, and this important, I will carve away an area adjacent to the spark plug like aone third
