chucketn
Senior Citizen
I found a sketch on CNCZone to control a RT with the Arduino that incorporates a 4x4 matrix keypad for input of #degrees of movement. It uses an I2C interface on the LCD to save inputs for the keypad. I have adapted the sketch to my setup, and it works well enough to make it a permanent setup.
I do have one problem I need help with. I can't get it to change direction of rotation. Could I get the Arduino/C++ experts to look at the attached sketch and see if they can spot the problem, please?
Thanks in advance. The same thread has modified the code to select movement by divisions or degrees, but I can't get that one to move at all.
Chuck
Code:
Degrees only
This sketch was downloaded from [URL]http://www.cnczone.com/forums/arduino/215402-cnc.html#post1461918[/URL].
It is the first sketch in the thread. I have modified it to match my setup.
Sketch works to set # of degree to rotate, but I cannot get it to change direction.
A program for controlling a single stepper motor driving a rotary table.
Uses a 4x4 matrix keypad for entry of degrees and direction to move the table.
Serial I2C display, Pololu stepper driver.
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
byte rowPINS[ROWS] = {11,10,9,8};
byte colPINS[COLS] = {7,6,5,4};
Keypad kpd = Keypad(makeKeymap(keys),rowPINS,colPINS, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x20 for a 16 chars and 2 line display
//setup vars
const int stp = 12; //connect pin 12 to step
const int dir = 13; // connect pin 13 to dir
const int StepsPerRotation = 200; //Set Steps per rotation of stepper
const int TableRatio = 90; //ratio of rotary table
const int Multiplier = (StepsPerRotation * TableRatio)/360;
const int stepdelay = 1;
float Degrees = 0; //Degrees from Serial input
float ToMove = 0; //Steps to move
int Direction = 0;
int repeat = 0;
void setup()
lcd.init(); // initialize the lcd
pinMode(stp, OUTPUT);
pinMode(dir, OUTPUT);
// Print welcome message to the LCD.
lcd.backlight();
lcd.print("Rotary Control");
lcd.setCursor(0,2);
lcd.print("by sloucs,on CNCZone");
lcd.setCursor(0,3);
lcd.print("Modified by Chucketn" );
delay(2000);
void rotation(float tm, int d)
if(d == 0)
digitalWrite(dir, LOW);
else
digitalWrite(dir, HIGH);
for(int i = 0; i < tm; i++)
digitalWrite(stp, HIGH);
delay(stepdelay);
digitalWrite(stp, LOW);
delay(stepdelay);
float GetNumber()
float num = 0.00;
float decimal = 0.00;
float decnum = 0.00;
int counter = 0;
char key = kpd.getKey();
lcd.setCursor(0,2);lcd.print("Enter Deg & Press #");
lcd.setCursor(8,1);
bool decOffset = false;
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
if(!decOffset)
num = num * 10 + (key - '0');
lcd.print(key);
else if((decOffset) && (counter <= 1))
lcd.print(key);
counter++;
break;
decnum = num / pow(10, counter);
key = kpd.getKey();
return decnum;
int GetDirection()
int d = 0;
lcd.setCursor(0,2);
lcd.print(" ");
lcd.setCursor(0,3);
lcd.print(" FWD[A] REV[B]");
while(d == 0)
if(key == 'A')
d = 1;
else if(key == 'B')
d = -1;
lcd.clear();
return d;
void loop()
if(repeat == 0)
Degrees = GetNumber();
Direction = GetDirection();
Degrees = Degrees * Direction;
if(Degrees < 0)
ToMove = (Degrees*Multiplier)*-1;
lcd.setCursor(0,0);
lcd.print("REV");
lcd.print(abs(Degrees),2);
lcd.print((char)223);
lcd.setCursor(8,1);
lcd.print("Moving");
rotation(ToMove,0);
lcd.setCursor(8,1);
lcd.print(" ");
else
ToMove = Degrees*Multiplier;
lcd.setCursor(0,0);
lcd.print("FWD ");
lcd.print(Degrees,2);
lcd.setCursor(8,1);
lcd.print("Moving ");
rotation(ToMove,1);
lcd.setCursor(8,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("To Cont Press [A]");
lcd.setCursor(0,2);
lcd.print("To Reset Press [D]");
while(key != 'D')
key = kpd.getKey();
if(key == 'A')
if(Degrees < 0)
lcd.setCursor(8,1);
rotation(ToMove,0);
lcd.setCursor(8,1);
lcd.print(" ");
else
lcd.setCursor(8,1);
rotation(ToMove,1);
lcd.setCursor(8,1);
lcd.print(" ");
lcd.clear();
Chuck
