firebird said:
Hi Dean
I've had a reply from the seller. The duty cycle is 20%. Is that good enough for hobby use???
Rich
Well, maybe. For the size of the one you're looking at, that's not really great. It's only 140 amps to
begin with, and if you want to weld with something like 1/8" 70xx rod, it's going to be shutting down
every couple of minutes.
The duty cycle does go up when you use lower amperage, so if you think you can weld down at the
bottom of the amp tap on that one, it may a few minutes or so before it gets hot.
One of my machines is an older Lincoln tombstone welder, like the kind Tin has mentioned. It has a
20% duty cycle too, but that is at 225 amps. At 70 amps, it's 100% and at 125 amps is about 70%.
I don't mean you should get a Lincoln. They are still a good price here, but would probably be a lot
there, 'cause they're fairly heavy. You might look around a little more to see if you can find a model
that will give about 50% at a usable amperage. Something that will run 1/8" rod for five minutes at a
stretch, or 3/32" rod for a bit longer than that. Then you will be able to sit down and get some practice
in without the machine constantly shutting off.
I wish you could get something British or European made with a good spec. I wouldn't buy any of the
Chinese ones. I've used two of those and have nothing good to say about them. They get hot fast, and
take a long time to cool down. The truth is they simply lie about the duty cycle.
I know some products in certain countries are simply more expensive than elsewhere. You may have
to take what is available.
Dean
