As a general rule, machining and welding are somewhat incompatible. I have a stick welder, a mig welder, and an oxy-acetylene welding set up, and while they are all great for fabrication, they all cause distortion in the metals they weld. Ask any senior machinist, and they will all tell you how nasty it is working on components that have been welded. If they had their way, everything would be drilled and dowelled and bolted together. If you can do it, buy a tig set up. If you can't, then consider that most stick welders capable of 180 to 225 amp output will give a far greater strength weld than any 110 volt mig, but you have to deal with the slag. A 110 Volt mig with a gas bottle won't give you much strength (as in weld penetration) but are clean, easy to use, and do great for "temporarily" sticking things together.
