alina k 24 test indicator
dethrow55
texas
hello all just purcashed a alina k 24 test indicator need a new bezel for this indicator. long island no longer sells parts for these this is a great test indicator made by compac swiss movement. any how thanks all
hello all made a mistake i need a crystal not bezel .old timers sorry.
You might try suppliers to watch makers. However I’m not too sure there would be any compatibility. Otto Frei might be able to help but they are more about tools than parts.
If they can’t direct you to a supplier maybe a cover glass off an old pressure gage could do the trick. Otherwise you will have to fabricate your own.
Here in Australia most of our major shopping malls have what I call kiosk type shops that replace watch batteries, often they will also be able to fit a new crystal - I'm guessing you would also have these in the USA. If you can pry the bezel off then one of these places should be able to fit a new crystal to the bezel. I have a Mitotoyo DTI and bumbled my way through the fitting of a new crystal after watching a few youtube videos, the crystal is almost flat and if it is supported on the outer edge and pressed in the middle the OD shrinks in size enough for the bezel to drop on, the crystal is chamfered around the edge, the chamfer fitting into a groove in the outer edge of the bezel, a crystal press is usually used but I managed to do it just with thumb pressure.
