Another couple of questions if I may:
What tolerances must I hold to prevent air bleeding past the spool on a basic valve, typical of the type I see used on small engines on this site. I want to achieve as close to zero as possible.
I see many valves from brass running in cast iron. Is there any reason why I may not use delrin in cast iron for a valve?
