Air Compressor for mist system?
Discussion in 'CNC Machines and Conversions' started by myrickman, Apr 14, 2019.
  1. Apr 14, 2019 #1
    myrickman
    myrickman
    myrickman
    Mar 6, 2009
    172
    64
    After countless trial runs machining foam and wood, I’m getting ready to make some aluminum chips. I have a mist system head and don’t want to use the very loud standard shop compressor. Has anyone tried using one of the larger aquarium pumps sold on eBay with the electromagnetically driven piston ? I’m seeing sizes of 70 liters per minute and larger. This one is 220v....
  2. Apr 14, 2019 #2
    Lofty76
    Lofty76
    Lofty76
    Member HMEM Supporter
    Jun 6, 2013
    9
    0
    Gender:
    Male
    Occupation:
    Technician Engineer (Rotary Wing)
    UK, South Coast
    Hi, if its any help, I use a compressor from a freezer, its almost silent in use, and delivers enough air for the mist head.
  3. Apr 14, 2019 #3
    myrickman
    myrickman
    myrickman
    Mar 6, 2009
    172
    64
    That’s a great idea Lofty. Never thought about that...and they’re free for the taking at the bone yard. Do you run it with the oil that is in it and does it get depleted through the air stream? Thanks for the tip.
  4. Apr 15, 2019 #4
    blanik
    blanik
    blanik
    Active Member
    Apr 6, 2016
    28
    7
    Myrickman,
    I don't know where you're located, but you might be able to find the following style of compressor from a supplier in your country. https://www.justtools.com.au/rolair-10lt-ultra-quiet-oil-free-air-compressor-jc10
    I've been using one for a while, and at 55dB, it is not silent, but by the same token, it's not noisy like a typical compressor. My machining workshop is a small room 4 x 2 meters, and I have the compressor sitting in a space under one of the benches. It's quieter than my 8" x 19" lathe.
    I hope that info helps.
    RoyG
  5. Apr 23, 2019 #5
    Baz
    Baz
    Baz
    Oct 5, 2009
    14
    3
    Had a bit of luck at a motorcycle jumble and picked up a small diaphragm air brush compressor, I have used it quite successfully on the CNC mill as a chip blower.
Draft saved Draft deleted
Share This Page
Group Builder
