Could you please advise on a couple of points i am not clear about ; The first concerns setting up to cut tapers using a taper jig i have made, how do you set the jig to the correct angle correctly ( it is a standard jig-you offset the bar) and do you cut the taper between centres or held in the chuck.
Second concerns Between Centre turning.is it possible without a faceplate and if so how ? as i cannot see it being done without using a lathe dog!
Thanks for your help
Coldte
Coldte
