6 cylinder flywheel engine
Rocket Man
All 6 cylinders are .375" diameter. 3 pistons are 90 degrees from the other 3 cylinders. The air ports are hidden with O rings to prevent leaks. All 6 pistons get air. I have never checked the RPMs it might be 1500 on 100 psi. 6 cylinders use up a lot of air.
https://www.youtube.com/watch?v=GIvymk3OgOg
