- Nov 17, 2012
- 333
- 943
An easier way to assess the value of the middle cylinder would be to run the engine with the two short link manifolds removed.
If it can drive a moderate load (e.g. a prop) at a measured RPM and a known throttle setting, then compare RPM with the manifolds replaced.
If a suitable RPM meter (e.g. optical type) is not available, just record the sound for comparison.
google Prony brake, it would seem to be a fairly easy way to measure horsepower, I think that there may be posts on this forum somewhere.One of my "round-tuit" notions is to make a dyno... does anyone have plans? (2 spring balances and a leather belt on a pulley?).
hello
here is the video
And Toyota et al are trying to utilise this effect in today's designs of engines....The five stroke engine is an old idea made new again.
In the steam era, it was called compounding with high and low pressure cylinders.
Also in the steam era, it was done with a single cylinder and called early cut off. Corliss engines did this.
Early cut off was also used in the internal combustion era. The atkinsons cycle which has a short intake stoke, but a long power stroke.
The whole reason is to extract as much energy from the expanding gasses before dumping them out of the engine.
Thermodynamics doesn't change.
...Ved.
