GWRdriver
Senior Member
- Jan 22, 2009
- 721
- 109
I need some 4mmOD tubing to make a short low-pressure main lubrication line. Annealed because I need to make a couple of bends, and stainless (preferred) because it's located in a vulnerable place. The original aluminum line was "bumped" closed (hence the need to replace it.) I might be able to make 3/16" line work (1/8" won't) but if possible I want to use the original 4mm compression fittings.
So my question is, is 4mm stainless a US automotive (brake or fuel system) item that I might find at a good automotive supply shop, or some other equally easy to access source?
