B
Bogstandard
Guest
I have been going thru my workshop bits and come across a fairly long term project, now that the grandson takes no interest, will never even be started.
It is everything to make the Seal engine. All plans and building instructions are included.
http://www.hemingwaykits.com/acatalog/The_Seal___Edgar_T_Westbury.html
The only things I didn't buy were most of the raw materials, as they cost too much from the casting supplier, they can easily be obtained much cheaper from a metal supplier. I think the cast iron for the liners is in there (not sash weight).
In fact there is a lot more to the kit than is normally supplied.
4 Rimfire plugs @ £16+ each
Full set of hi tension leads (5 off)
True moulded distributor cap
Tim 6 ignition system
A pair of very expensive skew gears. This, coupled with the distributor cap, allows you to have the external distributor and water pump as shown on the plans and the pictures, but not supplied with the kit.
There are no fasteners supplied, not even in the kit from Hemingway.
I can only offer this to UK members, as the postage charge to the offshore colonies would be very expensive.
£250 all inclusive. If you take off postage, this is about half price.
Email or PM if interested
If no one is interested , it goes on eBlah with a large reserve.
Bogs
Bogs
