I got dragged around an Ikea not long ago and discovered some interesting LED "work lamps":
http://www.ikea.com/us/en/catalog/products/20169658
They're a high-power one-LED lamp, about 1.25" diameter on the end of a couple feet of that bendable-conduit stuff with a wall-wart power supply. Ditching the base (looks like a chunk of really low-quality cast-iron), there's a couple screws and tapped standoffs in the end of the bendable bit. I drilled the plate on a spare hard-drive magnet and bolted it on.
It works well-- bright white light, well focused and far less susceptible to burnout and breakage as the bulb-based machine lights. Bonus is you don't accidentally roast the back of your hand if you get get too close. Plus, if you do send the slitting-saw-of-death through the cord or dunk it in coolant, you won't get fried...
Now how much would you pay???
