I've recently started on this model of an IHC Famous Engine, the castings are the original May Engine Works ones and have been through the hands of at least two members of this forum before being purchased by their current owner who I am building it for.
The kit contains 18 castings, 16 in iron and two in gun metal as you can see below, one of the previous owners had painted them in two shades of grey paint.
As an idea of size the flywheels finish up around 5 1/2" dia and the engine about 12" tall
The first part I tackled was the base casting, as the sides are tapered it was not going to be easy to hold so I shimmed it up on the mill and machined the top surface and tapped the four holes. I then drilled matching holes in a bit of flat alloy bar and used CSk screws to join the two, it was then a simple case of clamping the flat bar to the table so I could machine the bottom of the casting.
Next on the list was the crank case, again I machined the top then bottom and took a light skim around the 4 edges of the base flange so I would have 4 true edges to setup the casting with. I mounted it on its side between two angle plates and it was just a case of rotating 90degrees and then machining the next face.
I mounted the bearing carrier into the casting so I could bore that at the same setting as the fixed side to make sure all was in line.
And here it is with a few pivot pins fitted
The cylinder was a fairly straight forward boring and then drilling job followed by a bit of fettling with the Dremel around the various cast bosses
Finally for a change of material I did the Muffler parts, the cast elbow was from PM Research
Jason
Jason
