peterl95124
- Feb 22, 2020
- 428
- 258
how do you know its not one of the other "usual suspects"
compression (rings and valves sealing) ?
valve timing ?
ignition (getting a hot spark) ?
ignition timing ?
carburation (needle valve, throttle, gas flow) ?
after going through "all the usual suspects" I recently solved a non-starting
problem with some automotive starting fluid (AKA ether), turns out my arm
is no longer strong enough to flip the prop fast enough !
FYI Atkinson Differential engines are notoriously hard to get running, that one's not your fault !!!
valve timing ?
ignition timing ?
