Thompson Engine
Hey Michael.
Following your current build closely. (And the Demon build) What's the origin of the casting kit/plans ???
Is that a HM50/51 mill your playing with ??? I've got the HM52 H/V with plans to retrofit for CNC.
Trevor,
Melbourne, AU.
Hi Trevor
I got the engine kit from a member in the states that was selling some of hi casting kits
Looks like you can still get the kit from here 1945 Thompson Vertical Air Cooled
Yes that is a HM50 retrofitted to cnc
Milling Machine CNC 2).jpegMilling Machine CNC.jpegMilling Machine CNC 3.jpeg
Good progress on the kit
It is also possible to make a similar looking engine from scratch which is what I did from a few photos. There is also a bit about the history of the design in the first part of my build for those interested in the origins of this engine
https://modelengineeringwebsite.com/Thompson_four-stroke_1.html
Good machining and photography.
Getting good photography in a shop setting is very difficult for me, as is good machining sometimes.
I ALWAYS have good machining ....
.... it's just that sometimes my photography makes it look bad. Really. I'm sure that's what the problem is.
Oh, and bad videography. I assure you that the engine really is turning and sounding great, no matter what you see in my video. Scout's honor!
Michael,
thanks for putting up this build log. It gives me some good ideas on set ups when I start mine.
Mike
Worked on the head and got some of the holes drilled and the inlet and exhaust valve guides done
I drilled small pilot holes for the inlet and exhaust valves, the transfers to the four jaw on the lathe
I the drilled and reamed the valve guides, then drilled out for the ports and turned the valve seat
Back in to the mill and drilled the ports out, having the head screws to a square block made changing setups much easier
Hi Michael how did you decide dimensions for the insulator shape? Having worked with Champion selecting correct heat range plus for engines, I know this can be very difficult and "company secret" in industry...
HI
I don't know anything about the science of spark plugs
I am also in the process of building the Demon V8 and I have made the plugs for that, so I just scaled them up to the size I needed
Michael
Aha! I hope they work alright! Longer surfaces from live to earth mean you can run a higher voltage coil. Also means spark gap can be increased. But the cooling, or rather permitting the central electrode and insulator to reach a high enough temperature to stay clean, without burning, is often critical, so short initial runs and lots of checking is what I recommend.A melted electrode tip or overheated insulator can lead to broken bits flying around inside the combustion chamber. Oily plugs are a lesser issue.
But well done on the manufacture of nice looking plugs!
