Wiring teco VFD to my enco 13x40 lathe
EJay
Michigan
Hello to everyone,
I new to this site. I recently bought a teco VFD (p/n L510-203-h1-u) for my Enco 13x40 engine lathe. Does anyone have a schematic? I'm a machinist by trade. Not an electrician. So any help would be appreciated. I pulled off the front switch panel. There is a red(activates the motor switch),dark blue(activates green start button),light blue(activates coolant pump), and pink((hot wire which is ran thru all switches) which are ran to a buss bar on the back side of lathe. Can I hook up off the buss bar? Or should be hooking up on the other side of the contractors? I still having a hard time to decifering the wiring for the forward/reverse lever and the foot brake. Thanks for the help.
