Another PeeWee
Thank you Steve and Neil!
Steve I'm being able to work a couple of hours every day and some full weekend. Thanks for your help on this project.
My last work of the year on the PeeWee.
I have finished the intake manifold. I copied Michael process, was really strait forward.
It was not difficult to machine but, was really a work of patience!
I started machining 45° on both end and side to the largest lenght
Removing the material that will form the bolting flange
Moved to a vise with angle adjusting feature and set it to 45° to form the flange
More is coming on the intake
Edi
Hello People!
It has already passed several months since my last post on the PeeWe progress. Almost half year. The available time is short.
Here is some info. about the progress.
The crankshaft
Blank ready for the lathe operation
Roughing on the milling machine
Ready for the main bearing. To avoid warping, I used a bolt and nut to fill the offset space
Now is the turn of the ends. I used the lathe fixed steady as much as possible
More to come.
Edi
Some more details of the Crankshaft on the lathe.
Turning the ends
Machining the counter-weights
Checking out how it fits on the block
Before turning out the ends, what would cause to get rid of the center holes, I grinded the jornal to the final diameters
Back to the lathe for a skin pass on the FlyWheel for perfct balance
So this finish the hard part of the crankshaft.
Still needs to grind the ends.
Thanks,
Edi
Preparing the blank for the connecting rods.
This is the bottom portion of the connecting rod. I bored all the bolt holes including the small lubrication ones
Than I bolted the lower portion to the upper one.
Ready for the profile
Finished connecting rods. I made a program on the SprutCam
The throttle lever and bracket
More to come on the bearing bushings
TKS,
Edi
Hi to all!
As I do not like the process of soldering two halves of bronze for the bushings, I turn two complete bushings than machine out to the midle of the diameter so, we have two perfect halves
Machining out to the midle of the diameter
I made a kind of collet to machine the inside diameter
They come out perfectlly
Fitting test was perfect
Running freely and no play
The lifters made out of 12L14 steel
Edi
Nice Job Edi! Put two bearings on the rear of the crankshaft. Spot one flush with the outside of the block and the other on the inside of the block. Make them as far apart as you can get them. That will be a great support for the flywheel encase there are any issues with the flyslug being out of balance a little. Little sucker is heavy.
Hi to all!
Thanks Brian.
Steve, yes I added one more bearing. I had seen your recommendation in another thread and ordered one extra bearing for my PeeWee.
With the pistons and connecting rod installed
Everything was running smoothly than, I moved the block to the lathe for breaking in. I filled with a little excess of oil to perform the breaking in. Now I will remove the oil, Clean everything and fill with the right level of oil and run a few more minutes. I also tested the cameshaft. It was running OK and moving the lifters freely
I think that in one more month I will be able to make the first start.
Tks,
Edi
Here are some more pictures of the progress. It is not in sequence of construction.
Turned the valves
Grinding the valve stem using a adapted manual grinding o the lathe tool post
Cutting off the the rings. I used a 1mm wide cut off tool
Test of the ring on the piston groove
I separated the rings using a cut off plier used on electronic shops
I have used Bob's method to provide the spring effect on the rings.
Tks,
Edi
For the Liners lapping operation, I used a brass lapping bar
I have used a diamond paste for the final finishing. The inner surface come out very smooth
The Pistons
Milling the pocket for the connecting rod
In order to assure the hight from pin center line to the top of the piston, I used a long pin with the same size of the hole as a stopper
Edi
Hi to everybody!
A question/help for those that have built the PeeWee.
Did you guys face the same problem shown on the photos below? The fan is interfering with the center line of the crankshaft consequently hitting the starting shaft.
What did I do wrong? I already checked the drawings and the fan diameter is correct as well as the center line distance from crankshaft and fan shaft.
Comments, hints, explanation are appreciated.
Thanks in advance,
Edi
It appears that the dimension from the centerline of the crankshaft and the centerline of the fan boss might be off. The radius at the top of the timing cover and the boss for the fan should not be concentric. The fan boss should be shifted up from the cover centerline about 0.200 inches. It appears from your earlier photos that the boss did not get shifted up.
Shorten the fan blades.
