My first attempt to make the crankshaft from steel bar.
Hi All !
Update 2 - my V2 engine project :
after a lot of measure , test , think and measure again ..
with a few details in the trash
Result
20190417_182915.jpg 20190417_182936.jpg 20190417_183058.jpg 20190423_191510.jpg 20190423_191538.jpg
Hello Minh
Nice work I like your rocker arms but just my suggestion : on the push rods you have some brass parts
//probably for setting valve clearance // do it as light as possible because heavy push rods
decrease engine performance and rise stress on cam shaft lobes.
Hi kadora !
Thanks you for the opinions.
Hi All !
Update 3 - my V2 engine project :
Thanks for the praises !
Now, I can say: "start a new project with a design " and it could be a 2-cylinder engine with a water radiator before doing V4..., I need to learn more...
Nice job, love the V twin sound, was this totally freelance or ideas copied from something else.
Would love drawings or doodles if available. What ignition,plugs etc?
Hi IC-man !
It is freelance
I combine the available things, gears, ... and the things I can do
With plugs, I make it
I can draw it before doing it, but I don't know how to do it?
I don't have much experience in machining and knowledge like some of the members here, I try to think of it as two engines but combine it with a 90-degree angle, with the camshaft I do the 4th but it seems it is incorrect, every part of it has some in the trash
