Corian for spark plugs
Try countertop/cabinet installers for scrap corian. The sink cut-outs are good sources, as well as the little bits of scrap as thy fit them. I did buy some pen blanks from the US on eBay but I have tracked down local installers here in Perth (tho I haven't contacted any yet). I imagine Melbourne should be similar to Perth.
What do they call in here in Australia ? When I asked about corian they did not know what I was talking about .
Andrew in Melbourne
Possibly just something generic like 'acrylic counter top' but here in Perth I've seen local counter top suppliers websites with the name 'Corian' on them. I didn't find much on Google when I searched 'Corian Perth' but instead I just searched for counter top businesses and browsed their websites.
Corian is made from acrylic and alumina and is heat resistant to 100°C (per Wikipedia). On the one hand, numerous people have successfully made spark-plugs with on, but on the other hand it does not sound like an ideal material to me. I have not (yet) tried to make any spark-plugs, but I would be more inclined to use teflon, which in my experience machines well with sharp HSS tools.
The ideal material would probably be machinable ceramic, but hold onto your hat when you look at the price!
Nothing in our price range is ideal but it's the best cheap material out there. As an insulator it will out perform most materials we use in this hobby. I have the same plugs in the peewee that were put in in 2010 and I run it more than any other engine I own.
I have 3 engines running homemade corian plugs. They have run all day at the shows for years on the same plugs.
The only issue I have had is that the insulator is easy to crack during machining.
I have 3 engines running homemade corian plugs. They have run all day at he shows for years on the same plugs.
Can't disagree with that. Care must be taken when you machine them but also when you press the insulator into the base. I have cracked a few during that step also. Once they are done, you cant beat them.
The beads are over a buck a piece and are too short to make an insulator. The rods I saw were 27 bucks a foot and machinable but the forum I looked there was a guy who was blowing up diamond inserts trying to machine the stuff. Being ceramic I would think they are unable to be modified. Do you have any photos of the plugs made from this stuff Kimmo?
There's this chap Graham Meek on modelengeneeringwebsite who's done these plugs. He made the ptfe insulator with the bead on the head of the plug. There's drawing on site too.
OK. I'ts good to have few option. I think they all works fine, corian, beads and ptfe. Ptfe's possible chemical decomposition worries some guys, don't believe it's a big issue with these engines.
Some other possibilities: Soapstone (samples often available from countertop manufacturers), hexagonal boron nitride (nice and white, machines like graphite, good to 950C), Macor (machinable ceramic).
I suspect that the first time I want to make a spark plug, I will use HBN.
Goodfellow chemical: http://www.goodfellow.com/E/Boron-Nitride-Rod.html -- but their price is way over the top; I've had access to some scraps from laboratory work. I wouldn't make a plug out of HBN from Goodfellow.
There's a possibility of getting reasonable prices from vendors on alibaba. But you have to ask for a quote.
Ebay currently has some NOS steatite rods on sale -- 1/2 inch diameter by 8 inches long for $14.o0 with free shipping. Steatite is purified soapstone. It is reputed to be machinable, but I've never tried it.
