Press Fit
Maris Dislers
Adelaide AUSTRALIA
Hi Gang,
I built a small diesel engine that has a 3mm pressed-in crankpin. Didn't get the fit right and it came loose. No big deal - just make another hole in crankweb and try again. How much smaller should that hole be than the actual pin size? For folk who think in inches, think about fit for a .125 inch pin. Pin is a cut down needle roller, going into steel cranbkweb.
I'd consider silver soldering if there is sufficient clearance for the solder to 'wick'. File a minute channel for it to happen.
Norm
When silver brazing requires to keep parts precisely located I reduce the diameter about 0.006" (or whatever your alloy suggest) for let's say 3/4 of the length. It is better to have 3/4 of the length fully vetted than a spotty weak braze.
For a 3mm pin, you should look for .005 to .01 mm press normally
You don't say what the material is ? The above is for steel.
You should consider heating the crank to 150 -200 C to make the fit easier and stronger.
(Shrink fits are 2 x stronger)
Your hole growth will be about .002mm per 100 C if i did it right
Rich
