Reversing Valve for Air/Steam engines
Brian Rupnow
Design Engineer
Barrie, Ontario, Canada
I was so impressed with the way my new reversing valve worked on my double wobbler that I have to share it. This is by no means an original design, as I was helped by a couple of forum members to figure out exactly how this kind of valve would work. About the only difference in a valve like this working on steam as opposed to air engines, is that the air inlet tubes should be threaded into the main valve block and not just Loctited as I have shown. I know for sure that this reversing valve will work on a wobbler (oscillating) engine. I'm not sure if it will work on a conventionally valved engine like the Cretors Popcorn engine or not.
I have been showing at a local Steam Rally today (and tomorrow) at the side of a big reservoir. This year there are several small steam powered boats/launches? I spent a while talking to one owner and peering at his engine, a single cylinder oscillating engine with reversing valve that is very similar to yours Brian. Same principal, this design also appears in an early Tubal Cain (not the youtube one) book "Building Simple Model Steam Engines" with his build of "Hercules" a model crane. What really intrigued me was to see a "wobbler" powering a 12-15 foot launch with 6 people in it. Apparently thebasic little single cylinder ones are not just toys and very simple motors for me to try to make.:rolleyes:
I have ben using a different design for my steam engines for the last few years because they don't leak if you make them right.
Here is a sketch of what I am on about, plus they are very versatile, you can control all sorts of issues with them, from normal speed and reversing to use on my large turbine to feed both types of jets.
Hope this helps
Brian,
Built one yesterday, no build log, sorry, done rear outlets, all drilled and tapped 1/4-40 for live steam, still have the lever to do, need to get material, also made up a lot of fittings for a boiler
Andrew
We all know what curiosity done to the cat. Ever since I designed this reversing valve, I have wondered if it would work on a conventional steam engine or not. Today, due to absolute boredom, I got one of my more conventional steam/air engines down of the shelf and modified it a little bit so I could hook the airline to the exhaust pipe. I didn't think it would work, and I was right.---It didn't. So--it works on wobblers, but not on conventional engines.
The deeper I get into this, the more I learn. the reversing valve will work on both "oscillating" and "piston valve" style engines. It won't work on slide valve engine es.
Brian, made a reversing valve of your design to go on a Norbert Keeley wobbler.
works perfect!! :)
thanks, Marv
It won't work on slide valve engines.
That is what I thought until I ran across the Soule Speedy Twin, which has slide valves, and a reversing valve similar to the one you show.
I did a lot of head scratching before I figured out how the Speedy Twin kept from lifting the D-valves off the seats when the pressure on them is reversed.
