The built has begun!
Hallo Natalefr,
Thanks for your interest in my Model Engine Thread.
I do try to make my own small model combustion engines beneath my hobby tinkering at old factory model engines.
I have many doubts if the combustion engine will survive because of the dirty air there come a lot of chances for other kind of engines i think.
However at this stage it's still possible to try to make a little motor my own which only runs for a short time after finishing the job then another new project is already on my desk again .It keeps me busy and alive which is a very good thing in my opinion.
About my latest project the MP 3,2 cc MODEL ENGINE there still need to be made a Piston,a Conrod and a Wristpin after assembling the engine it will have to run let us hope so.You will see one photo from several engines i already made till today,missing is a big 8,02 cc glow engine with side exhaust and rear rotary valve looks great and sturdy will send a picture later on.
A few runners are already in my possesion under [email protected]
Hallo Model Engine Friends,
I did had to make some new parts for my MP 3.2 cc model glow engine because of the fact that i did n't like the first examples and enough time now with an age of 68 years to make some new parts which i like more.
I hope that you like the new parts i made till now as well.
Many greetings from modelmotor-Gerard-The Netherlands-Europe.
Hallo Model EngineFriends,
Enclosed a continuation from my latest photos made by myself.
Hope that you like them.
many greetings from modelmotor-Gerard-The Netherlands-Europe.
After a long time of absence because of medical problems which throw me in a mood of having lost a great bit of my interest in making model engines i decided to finish the MP 3,2 cc when i feel Ok to do so.
I do n't know if there will come a continuation of this beautifull hobby.
I do have a lot of factory engines as well and i often had the idea to make missing parts for these engines and try to let them run just like in former days.
I did n't make much photos last couple of months because there were no further parts finished or even started with.
So i send the last photos i made before i start visiting the hospital to often i hope you like them.
,any greetings from modelmotor-Gerard-The Netherlands-Europe.
I like to show you in which stage the build from my MP 3,2 engine is at this moment.A number of photos will show you the making from a conrod and,the finishing from several other engine parts.
I hope you like the photos i made from this work.
Many greetings modelmotor-Gerard-The NetherlandsEurope.
A continuation from a couple of photos so this set of photos has been completed.
hThere are a couple of photos left so here they are.
The next target to fulfil is making the Piston from Meanite Cast Iron which is Ok for the purpose of this model engine.Then i have to make the Wristpin which will get a press in fit into the skirt of the piston.
I hope that you like my engnine work as so far.
Many greetings from modelmotro-Gerard-The Netherlands-Europe.
Hallo Friends,
Still another couple photos to show you busy with my Conrod all hand crafted pitty no CNC machinery or something like that.
I hope you like it.
Hallo CKSHEVY,
Thanks for liking my posts.I apreciate it very much happy that you love the engine work.
Greetings from modelmotor-Gerard-The Netherlands-Europe.
I am continuing my job to build the MP 3,2 cc model glow engine.
I made photos of course from each engine part i make.I have to polish many of my engine parts later on,but the photo's are here to give you an idea of how it will look after the work has been done.
I hope yyou like the photos.
I like your posts. I'm hope your lathe chuck never picks up the rags under it. That could be a huge safety problem.
Hallo bdrmachine,
You have fully right by warning me about the safety risk when the rags wold picked up by the Chuck from my Lathe.
I normally use a piece of cotton on the bed of my lathe to protect my lathe from small Cast Iron particles which will come free when turning a short bar of Cast Iron to make the Piston from for my MP 3,2 cc.I will take care when putting some protection material under the chuck because an accident can happen very fast you are right so thank you for your reply/warning message.
MP 3,2 cc model engine 001.JPG MP 3,2 cc model engine 001.JPG MP 3,2 cc model engine 003.JPG MP 3,2 cc model engine 004.JPG 001.JPG 002.JPG 003.JPG MP 3,2 cc model glow engine 001.JPG MP 3,2 cc model glow engine 002.JPG MP 3,2 cc model glow engine 002.JPG MP 3,2 cc model glow engine 003.JPG MP 3,2 cc model glow engine 004.JPG MP 3,2 cc model glow engine 004.JPG Hallo Model Engine Friends,
Here are my latest photos i made from my model engine.You can see the making from the Piston and some other toolings
I hope you like the photos i made from this part of the action!!
I just would start reaming the liner for my model engine.I use for that purpose a adjustable handreamer from the Factory of "Hunger" situated in Germany-Europe!
Normale these Reamers are ideal for this kind of work and made very presizely from high quality steel .I found a problem with my Reamer and that's a broken Nut for the adjustment to make at one of both sides of this reamer.
After making a few phonecalls i found out that Nut was available in my hometown so i have to order for this Nut directly by Hunger Germany.It seems that the screw thread in the Nut has been broken at two placesand that either the Nut or that part of the Reamer that's functioning by the Nut has a kind of deformation.My photos will show you what i mean at least i hope that they are giving a clear sight on the small pieces of the broken screw thread from the Nut and the deformation from that part of the Reamer that needs to be used to make the correct adjustments at the Reamer.It seems that the Nut could turn nomore easily on that part of the Reamer itself.
Many greetings from modelmotor-Gerard-The Netherlands-Europe.reibahlen Fabrikat HUNGER 001.JPG reibahlen Fabrikat HUNGER 003.JPG reibahlen Fabrikat HUNGER 005.JPG reibahlen Fabrikat HUNGER 004.JPG reibahlen Fabrikat HUNGER 005.JPG reibahlen Fabrikat HUNGER 006.JPG
I have done some work at myMP 3,2 cc model engine again.I have made some photos from what i tried to make at home.I hope you like thesephotos from internal parts MP 3,2 cc model glow engine 001.JPG photos from internal parts MP 3,2 cc model glow engine 001.JPG photos from internal parts MP 3,2 cc model glow engine 002.JPG photos from internal parts MP 3,2 cc model glow engine 004.JPG photos from internal parts MP 3,2 cc model glow engine 003.JPG photos from internal parts MP 3,2 cc model glow engine 006.JPG photos from internal parts MP 3,2 cc model glow engine 007.JPG photos from internal parts MP 3,2 cc model glow engine 010.JPG photos from internal parts MP 3,2 cc model glow engine 011.JPG photos from internal parts MP 3,2 cc model glow engine 012.JPG photos from the making of the MP 3,2 cc engine.
Many greetings from modelmotor-Gerard-The NetherlandsEurope.
Here are the last photos at this moment from my MP 3,2 cc model glow engineMissing parts are already made as well.I have had several problems with making the portings in the Liner and still it is n't as it should be.My knowledge about this subject is not available enough to succeed so i will first try to find out what's the best way of making the portings into the liner.My illness is with me each day and makes that i can n't do much need to live more carefully not risking stress and getting tyred of all the things during the day.
However i will go further with an engine i finished succesfully ,but with a bad made piston so an engine which can run as tried ,but which still needs to have a much better compression.
I hope you like these photo's as well.
Many greetings from modelmotor-Gerard-The Netherlands-EuUnfinished MP 3,2 cc model glow engine cause problems making por 002.JPG Unfinished MP 3,2 cc model glow engine cause problems making por 003.JPG Unfinished MP 3,2 cc model glow engine cause problems making por 003.JPG rope.
