- Dec 12, 2012
- 2,220
- 1,285
I planned to make 6 locking pins from 12mm dia bar,one for each station
inserted from the bottom with a nut to pull up from the top.However I
realized the pins would clash with my locating ratchet on the u,side so
had to mount from the top with a nut clamping down.I also made only 3
each one clamping 2 stations.These will be locked/clamped tight while
I machine the 6 housings.
The housings will be nom 22 to 25 mm dia and can be machined in either
the lathe or the mill.I envisage centre drill and small step drill in the lathe
for accurate alignment the transfer to mill for more oomph.Final size will be
the boring head.Mine has an R8 spindle for the mill but would prefer to
finish in the lathe with light cuts.For that I will have to adapt to MT3
Will see how it pans out when I get there
