Very cool. I've been looking for the plans for this engine for a long time. Any chance could get a copy from you. Oh by the way what type of mill are you using?
Further to Ozzie46 link if you go to the subscribe tab and then carry on as though you want to subscribe this will take you to where you can buy back issues in digital format.
Yes it's only 6 bucks for each issue, I think I ended up paying 24 bucks cause the plans reference articles in #7 and #8 the plans are in issues #10 and #11.
It's good to support the magizine because the have really good information that passes on years of experience from other builders. All in which is invaluable to me!
Here's where I'm at in the project!
Thanks
Guys I picked up the subscription and got issue 10 and 11. But looks like I need to get 7 and 8 now. I'm gathering up the materials now. I know a guy here in Ohio that made his a twin cam seen the video but would like to see in person. He just does not want people over at his shop.
Thanks Again
Keep up the good work
Make sure you cover your ways and cleanup very good once your done. I seen a trick that Keith Fenner did from Turn Wright Machine (YouTube) is he turn his cutter over and ran it in reverse so the chips would go straight down and could be picked up with a vacuum. Looking great I cant wait to start mine.
I'm a little stumped on building the cam housing. To get the dim on the angles which are 25° each side, the dim to the top where the angle starts is .947 but there are r.063 on each corner. So to find my dim do I take .947 minus the radius of r.063 to get .884 then move from 0,0 to .884 in the Y direction then move the table 25° and make my cut moving the x axis?
Long story short I'm trying to find the Y dim from 0,0 to make my 25° cut.
Only the two outer corners are radius 0.063. The radius at the top is .147" with its ctr in the middle of the bolt hole that is 0.800" up. This gives the overall height of 0.947.
If you rotate your table 25 degrees then set the cutting edge of the tool 0.894 from the centre point 0,0 it will meet the 0.147" rad at a tangent.
I actually cut these angles and did the cam follower holes all in one setting with the part mounted on teh jig shown on teh drawings with the rotary table mounted vertically. In this case bottom of tool 0.894" above the pivot point.
