- Dec 12, 2012
- 2,220
- 1,285
Will give a brief description of my latest project with photos mostly self explanatory.An independant 2 jaw vise for the benchmill Cheap and easy to make and very useful.Low profile 35mm high.4.5" wide jaws opening to 12"
Basic principles have been around a long time.I remember as a young apprentice different versions being used on large Plano/Millers etc using the tee slotted tables to grip large irregular shaped castings etc.This one i made from bits of scrap.Details,dims and matls can be decided upon to suit your own requirements
The fixed jaw i made from 50x50x8 angle x 115lg,shaped and slotted to pick up
the 3 T slots.2 stiffening gussets were welded on and a 12w x 3dp slot to the u/side with a 12sq key fitted.A removeable jaw was was made from 40x12 flat and fixed with 3 no M12 cap screws
The adjustable jaw was also made from 50 angle with a 50x10 lat welded on.No gussets slotted the same with the 12sq key fitted.The moving jaw was made from 40 x 16 flat. Drilled and reamed for 2 no 10mm guide pins
The Screw was made from a 1/2W bolt the end turned down and grooved
to fit a 5mm ball locked in with a grub screw.Adjustment only needs to be 10/15mm.With the jaw open the two units can be set approx 5mm larger than the job with nom 5mm or so fo clamping.Final job was to skim the top of the vise jaws and mill a 10w x 4mm dp slot on the joint line.Additional
jaws can easily be made and say Veed for round bar etc.Will let you know when i use it.If i was starting again i would use a a longer leg angle say 65mm
that bolts to the table with the 35/40 high leg as is
