My lathe
Lordgarth
Just finished restoring this older Sherline ImageUploadedByModel Engines1396623525.590762.jpgImageUploadedByModel Engines1396623544.059058.jpg
Sent from my iPhone using Model Engines
That looks great.
Now, what are you going to make?
Thanks. Well I'm going to build a mini steam engine castings from PM research. I'll post some pics when I finish
Beautiful - almost has a "steampunk" look to it. I mean that as a compliment - it could go in my drawing room as a piece of art (if I had a drawing room).
Thanks kquiggle I appreciate your high praise
So where did you get the base looks like an import tool box base .
Tin
I made the base.
I put the lathe motor inside and the motor that drives the cross slide too
The base is made of teak because of its water resistance and high durability
Nice !!! Hope you were not offended by me thinking it was an import. Grizzly and others do sell similar intermediate tool chests.
Tin
No I took it as a compliment thanks
Definitely shows craftsmanship.
Hats off to the guys that take the time to build in there shops.
Tin
Very nice craftsmanship. How will cutting oils and solvents work on that finish?
Most furniture polishes are oil based
So as long as I wipe is clean after a project it will be fine
Do you use that dial test indicator holder as a length stop as well?
The whole set up is very classy, I've been thinking of doing something like this to my machine too.
Wow, the cabinet and lathe look great and very handy for keeping the tooling together. I like the location of the power controls so you don't have to reach over the lathe when it is running. Nice set up to indeed!
