- Jan 4, 2011
- 1,332
- 343
Sometimes short cuts do not save time but actually add time.
I have been working on Paddleduck two cylinder engine. Plans are free and available as the original sketches or as DXF/DWG. I downloaded the DXF drawings and loaded them into my CAD program. The drawings are metric and I want inch sizes so I rescaled them 1/25.4 and everything looks good. I also have been trying to set up and learn CNC on a small Grizzly mill and this looked like a good project to experiment and learn on. Unfortunately what is close enough for manual work is not necessarily close enough for CNC. 20MM=.7874in which is generally close enough to 3/4" (.75) but it is about 1/32 off and when the mating piece is also 1/32 off in the other direction it means things do not line up by 1/16. When it is loaded into a CNC program the program just does the cut or hole where the drawing placed it without compensating for the slight error in conversion.
I should have just redrawn the whole thing from scratch instead of trying to use the DXF. Lots of little variations which I would have picked up had I been doing manual milling.
The good news is that I am learning a lot about the CNC mill. I can now make a part which would have taken me three hours manually and after experimenting with the program, learning how to run the program and remaking the spoiled parts using the CNC mill I can do it in only three days. Don't laugh, it was five days the first time. Good thing this is a hobby and not my means of earning money.
