Milling an arc?
JeffF
I have searched the internet for days looking for how to do what I'm about to ask, but can't find anything for manual mills, only CNC articles. For some reason, I just can't get my head wrapped around this.
It will end up being two base standards to hold a flywheel between them. The flamelicker I am working on (the one Cogsy made) is the engine I am making these for.
Can someone tell me (or, even better point me to a video) on how to do this on the mill? I do have a rotary table, although I have yet to use it. Is this milled laying on it's side, or standing up?
I guess what I am looking for is a "how to" of how to mill ouside arcs on flat pieces.
Jeff
Rotary table laid flat on its back set the axis of the table to teh spindle axis, mark out all the centres of the arcs and locate each centrally under the spindle then offset the radius of the arc plus half the tool diameter.
J
If you want videos of rotary table use, youtube has some. Use the "rotary table" in search line. There are two below to get you started. The first is doing the radius by rotating by hand a plate. The second give you an idea though it isn't that great in instruction quality.
[ame]http://www.youtube.com/watch?v=am5774rnjtU[/ame]
[ame]http://www.youtube.com/watch?v=-RGyP6PYnGc[/ame]
It is hard to describe the operation without seeing a set up of rotary table use. They are very handy for arced profiles. Math is needed for the complex arcs thou switching from linear measurements to degree measurements.
It is hard to describe the operation without seeing a set up of rotary table use. They are very handy for arced profiles. Math is needed for the complex arcs thou switching from linear measurements to degree measurements.>
Those were helpful. I have watched tons of videos talking about the rotary table in general, but can't seem to find any that show someone milling out an actual arc. The second video you linked too, does at least show a small version of that. I wish I could find one that shows how to set up a piece on the table to mill a top arch (like one would see on the top of a support piece for a flywheel) and then see the actual milling process. I am less concerned about getting an exact arc, than I am just figuring out how to make any arc at all, since in this case, it is decorative only.
Nevertheless, thank you!
Jeff
In the book "The Shop Wisdom of Philip Duclos" ISBN13:978-0-941653-04-6 which can be purchased from Village Press in Traverse City, Michigan, USA. there are plans for a number of very neat engines, how to make your own piston rings, and an in depth article on how to make a curved spoke flywheel, which does indeed incoroporate the milling of arcs, and all of the attendant geometry for laying them out.---Brian Rupnow
If you cant wait, the instruction pamphlet from the Sherline rotary table shows some of that, and should be available for download on their site.
This doesn't explain how to mill an arc but may show you the concept.
Assuming you do not have a DRO with the software to do this, if you provide me the details of the arc, starting position will be 3:00 as on a clock with 6:00 being the Y handle 12:00 being the machine base, Radius of arc, size of EM, # of points that you would drill and total degrees of arc.
I'll copy the results in X-Y position, So you end up with a saw tooth profile from the holes, then file/grind the arc smooth. I have found that a pilot hole of .125" then follow with a 1/4"EM worked best, advance 60% of the EM Dia.
