Hello all,
Building a single cylinder 4 cycle engine. I want to know if I install the spark plug on the side of the head Vs on the top of the head makes a difference?
If is on top, the spark will happen directly in the combustion chamber but if the spark plug is installed on the side will not have direct contact. I'm not sure if I'm describing this correctly or not but wanted to make sure if it cause an issue with running?
Thanks
Borna
Thanks
Borna
