Home Model Engine Machinist > Building Them > Questions and Answers > edge finder
Thread Tools Display Modes
Old 09-08-2010, 06:45 PM   #1
speedhound
Liked 1 Times on 1 Posts
Default edge finder
Hi, im thinking of buying a touch point edge finder thing something cheep around £25 are they any good and if so which one is best.
Thanks
speedhound is offline
Old 09-08-2010, 08:04 PM   #2
Jasonb
Jasonb's Avatar
Liked 319 Times on 190 Posts
Likes Given: 13
Default Re: edge finder
I use mine all the time and find them very accurate, get a shank that will easily fit a common collet, I use a 1/2" one. And they don't work with plasticas as the part needs to be able to conduct electricity.
Got mine from Greenwood Tools but can't see them on their site now.
Jason
Jasonb is offline
Old 09-08-2010, 10:21 PM   #3
Blogwitch
Liked 173 Times on 159 Posts
MSC/J&L have one left in their stock clearout.
Starrett quality
http://www.mscjlindustrial.co.uk/STC.../product.html#
I have no idea how this type works, but sounds good by looking at the extra info.
Bogs
Blogwitch is offline
Old 09-09-2010, 07:56 AM   #4
Jasonb
Jasonb's Avatar
Likes Given: 13
Bogs I think thats to set you tool height not an edge finder. It works by completing the circuit as the cutter touches the top of the tool and lights up, the tool is an exact height say 2" above the table so you then set your Z axis to 2".
Jason
EDIt looks like the picture or description is wrong, as search for the Starret 827MA comes up with this which is an edge finder
http://www.toolbench.co.uk/Starrett-...0mm-PSTR827MA/
Also if you tend to work in imperial get one with a 0.200" tip as its easy to workout the offset, trying to do it with a 6.0mm tip may be a bit of a pain
Jasonb is offline
Old 09-09-2010, 08:47 AM   #5
Blogwitch
Jason,
I have had an imperial Starrett for well over 20 years, and is still as accurate today as the day I bought it.
I noticed that as I was browsing thru their massive clearance list. If it is a tool height setting one then that is a real bargain, because the cheapest I have seen was about 70 squid.
Old 09-09-2010, 01:20 PM   #6
mudbug
I've had one like this for years. I find it works just as good as the expensive ones.
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=942655
mudbug is offline
Old 09-09-2010, 03:36 PM   #7
shred
Liked 33 Times on 33 Posts
Yeah, I've got one of those height-finders a friend gave me.. looks identical to the pic but doesn't say 'Starrett' on it anywhere. It works well, especially after I banded an alligator clip and a foot of wire to the base for use on non-conductive materials. Clip the wire to the tool or machine somewhere in that case.
I'm not sure why they cost so much though; it seems like it would be pretty easy to whack one up and surface-grind the tip to set the height.
shred is offline
Old 09-09-2010, 05:19 PM   #8
Majorstrain
Liked 13 Times on 12 Posts
I made one a while ago because as Shred said, they seem to be over priced for what they are.
Here is the topic link. Just in case you got the urge to make one.
http://www.homemodelenginemachinist....53889#msg53889
PDF file attached to the first post
It's sprung so that if you lower the cutter too much you don't damage the cutter. It could be used on a CNC but it was designed for a manual machine.
It has a buzzer instead of an LED
Phil
Majorstrain is offline
Old 09-09-2010, 05:32 PM   #9
don-tucker
don-tucker's Avatar
Liked 92 Times on 58 Posts
Likes Given: 20
Of course there is always the 1/4" dowel and a bit of fag paper
Don
don-tucker is offline
Old 09-09-2010, 09:59 PM   #10
firebird
Liked 75 Times on 75 Posts
Hi Speedhound,
I have one of those edge finders and got on fairly well with it until the day I wound the table the wrong way and bent it. With a lot of care and patience I managed to straighten it out again in the lathe using a dti. About 2 years ago I treated myself to a laser centre finder and I absolutely swear by it. They are deadly accurate and can also be used for picking up centre punch dots as well as edges and of course you don't have to worry about halving the reading, where ever the laser dot is just zero your dials. They are not cheap however but to my mind worth every penny. Heres a link to one company that sells them (usual disclaimer)
http://www.chronos.ltd.uk/cgi-local/...3aLCEFP#aLCEFP
heers
Rich
firebird is offline
Edge Finder Operation metaldestroyer Tools 12 08-06-2014 05:04 PM
Edge Finder Heads Up Ken I Tips and Tricks 28 08-24-2012 01:13 AM
How to use a Conical Edge Finder vascon2196 Questions and Answers 6 04-25-2012 01:57 AM
Micro edge finder Swede Photos and Videos 5 11-23-2011 04:26 PM
Laser edge finder don-tucker Questions and Answers 21 12-03-2010 02:51 PM
