Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > stuart 10h engine plans
Old 08-19-2010, 11:43 AM   #1
drileyeng
Liked 2 Times on 2 Posts
Default stuart 10h engine plans
I was just building crank and set plans on fire can anyone out there after they have stopped laughing their heads off help me with my problem.
drileyeng is offline
Old 08-19-2010, 11:58 AM   #2
steamboatmodel
steamboatmodel's Avatar
Liked 12 Times on 12 Posts
Default Re: stuart 10h engine plans
I am sure they will sell you more,
http://www.stuartmodels.com/
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
steamboatmodel is offline
Old 08-19-2010, 12:09 PM   #3
GWRdriver
Senior Member
Liked 110 Times on 91 Posts
Likes Given: 27
D,
If you are in the USA I can help you, but if you are in the UK someone over there should step forward shortly.
FWIW, it's fairly wide-spread practice among model engineers to make "bench" copies of plans, even large sets of plans, so as to keep the originals clean and use the copies to fold, fingerprint, mark up, and set alight.
Harry
GWRdriver is offline
Old 08-19-2010, 03:16 PM   #4
Troutsqueezer
Troutsqueezer's Avatar
Liked 32 Times on 51 Posts
With just a single post, can we be sure you are not someone who is just fishing for free plans? The legality of what you are asking is questionable even if you did burn your plans. How about an introductory post in the Welcome section? Got any pics of the build so far?
-Dennis-
Once you see the bandwagon, it's too late.
Troutsqueezer is offline
Old 08-19-2010, 04:41 PM   #5
bearcar1
Senior Member
Liked 43 Times on 43 Posts
"Got any 8's?" ......... "Go fish." ........
Um... sorry, I was back on the team bus traveling to an away game. An introduction and a short bit about your interests and your build so far would be nice, with pictures, even better. Other than that, most builders here are not usually in the habit of the supplying such replacement drawings, it is against the law you know. However, there are many Stuart suppliers that would be happy to accommodate your request quite readily. The 10H is one of my favorite engines, something about a cast trunk guide and slipper shoe that is visually attractive. Good luck with your project and do let us see some of your progress.
BC1
Jim
bearcar1 is offline
Old 08-23-2010, 05:50 PM   #6
dsquire
dsquire's Avatar
Liked 30 Times on 27 Posts
Pictures of the start of this engine may be found at the following link.
http://www.homemodelenginemachinist....?topic=10456.0
Don
Good, better, best.
Never let it rest,
'til your good is better,
and your better best
dsquire is offline
Old 08-24-2010, 11:11 AM   #7
fltenwheeler
Liked 25 Times on 24 Posts
Originally Posted by GWRdriver
D,
Hi
I inhered a set of castings for a Railroad Supply Mill engine with out the drawings. Luckily I was able to track down the original designer that provided me a set. Since then I have started to scan some of the drawings I have.
I would think that it would be legal to “loan, sell, or give away” a set of original drawing?
Does anyone know if the complete build series for the Wyvern is in “THE BEST OF MODEL ENGINEER MAGAZINE VOLUME 1”
Thanks
Tim
fltenwheeler is offline
Old 08-24-2010, 11:36 AM   #8
GordTopps
GordTopps's Avatar
Likes Given: 11
Tim
Yes it is
Gordy
Anyone who never made a mistake never made anything
GordTopps is offline
Stuart Engine jaykay Plans 5 05-22-2012 07:53 PM
Stuart 10V plans Aquarius21 Engines From Castings 7 10-10-2011 10:54 PM
No plans overhead valve steam engine and HMEM plans engine rcmadness Finished Projects 3 11-24-2010 11:57 AM
Stuart #4 plans? stevehuckss396 General Engine Discussion 0 10-31-2010 12:40 AM
Plans for Stuart 10h drileyeng General Engine Discussion 1 08-23-2010 05:55 PM
