Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Swing Up Threading Tool
Old 08-05-2010, 05:42 PM   #1
lugnut
Liked 15 Times on 14 Posts
Default Swing Up Threading Tool
A post a while back about a Swing Up Treading Tool stuck in my mind. So when it became time to thread the neck of the ER collet chuck I built this week, I made a temporary version of it. Along with the ability to instant reverse my little lathe, and it's variable speed capability (the Treadmill motor) the tool worked great.
So yesterday I rebuilt the tool for a permanent deal, and thought I would share some photos of it with you.
I used a threading tool bit holder that I've had for some time. Cut it off and drilled a hole for the guide pin and one for the pivot pin.
I used one of my tool holders for the mount, Added a little light duty spring to assure the cutter would drop into place.
Tool uses carbide tips that I have several of. Now I'm not afraid of treading any more. I only wish I didn't have to change them damn gears to do it.
Mel
Mel Larsen
lugnut is offline
Old 08-05-2010, 05:49 PM   #2
Paolo
Liked 29 Times on 27 Posts
Default Re: Swing Up Threading Tool
Nice idea...I did mine following Bogs idea...I remember now..I have a same tread tool but I'm not able to find the carbide tip suitable for it...!! Well done anyway!!
Paolo
I'm happy to exchange my experience with others enthusiast...And Today happily retired!!!!
Paolo is offline
Old 08-05-2010, 06:05 PM   #3
SAM in LA
Liked 36 Times on 36 Posts
Mel,
I built one of those earlier this year.
One thing that you must do is assure yourself that the tool returns to the horizontal position.
Mine would get swarf in it which would not allow the tool to fully return to its cutting position.
Consequently, I now make sure that it is clean before each pass.
SAM
SAM in Lower Alabama, USA
SAM in LA is offline
Old 08-05-2010, 06:08 PM   #4
lugnut
Paolo, those carbide tip are available from Grizzly, part number G7041 five for $10
Here is a link. http://www.grizzly.com/products/Carb...he-G7030/G7041
Mel
Mel Larsen
lugnut is offline
Old 08-05-2010, 06:28 PM   #5
Paolo
Woo Thanks a lot Mel..I'm placing an order...Thanks again
Best regards.
Sam...
maybe it was too short? I didn't encountered that problem yet...But I'm on alert now...
Paolo is offline
Old 08-05-2010, 09:17 PM   #6
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 694 Times on 518 Posts
Likes Given: 73
Very nice indeed Mel. I know you said it worked great, but did you find it any easier than normal single point cutting?
I used mine all the time when single point threading and it made life a lot easier. To such an extent, I used nothing else.
Sam, when I designed mine, I was very careful to leave 1mm gaps in critical places, just in case swarf got thrown towards the tool. But after using it a fair while, I found swarf wasn't a problem at all.
For those who might have missed the original design and trials.
http://madmodder.net/index.php?topic=2323.0
Bogs
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Retractable threading tool bronson Tools 40 04-15-2013 03:14 PM
Threading tool holder ksouers Tools 18 03-17-2010 02:46 PM
New threading tool, comments fdew Tools 14 04-14-2009 04:09 AM
Making an internal threading tool Wannabe2 Tools 14 11-14-2008 11:50 AM
Small Threading Tool rake60 Tools 26 10-07-2007 10:59 PM
