Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Cheap ballscrews - your advice/experience?
Old 07-12-2010, 08:34 AM   #1
Simon0362
Liked 2 Times on 2 Posts
Default Cheap ballscrews - your advice/experience?
Hi All,
I am about to add ballscrews to my existing BF20 CNC conversion (working pretty well on the combination of steppers, original screws and some home assembled electronics as well as Mach3) and I am bemused by the price differences between what is available.
I can source (from linearbearings.com) a set cortresponding to what I think I need (X: 1605 x 600, Y:1605 x 390, Z: 1605 or 2005 x 600) for around 150€ which are shipped directly from China. All other souirces (e.g. ArcEuroTrade in the UK want the same amount of money for a single ballscrew.
I am aware that 'you get what you pay for' but there is also a point where the cheap item is good enough for the job in hand - I am not working at aerospace tolerances and can accept some quality issues and I am also on a budget.
Has anyone else gone down the linearbearings route or any similar supplier or is the general experience to pay more for some guarantee of quality?
Your thoughts much appreciated.
Simon
Simon0362 is offline
Old 07-12-2010, 08:49 AM   #2
Tin Falcon
Tin Falcon's Avatar
Liked 815 Times on 647 Posts
Likes Given: 18
Default Re: Cheap ballscrews - your advice/experience?
Here is a place that has 5/8 x.200 pitch ball screws an nuts nuts $ 24 screw IIRC $11 per foot.
http://www.roton.com/Mating_Componen...family=7059321
they do have other sizes but more money hop this helps.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 07-12-2010, 09:46 AM   #3
rcfreak177
rcfreak177's Avatar
Liked 69 Times on 58 Posts
Likes Given: 70
Hi Simon,
I have actually purchased ball screws from Linearbearings through Ebay some time ago,
I have found the product to be extreamly good for the price and zero backlash. I fitted them to a 9x20 lathe which I retrofitted to cnc and the repeatability is excelent. I would definately buy them again. The shipping was around 2 weeks to Australia. The funny thing is I have Thompson ballscrews on my cnc mill, they sound crunchy and have approx .004" backlash, mind you they are the budget model (which is still triple the price of the ones from China). I will be soon fitting the Linearbearings screws to that machine as well. Here is the link to the store.
Regards Barry.
http://stores.shop.ebay.com.au/linea...__W0QQ_armrsZ1
Fear and doubt knocked on the door,
Courage and confidence answered and there was nobody there.
rcfreak177 is offline
Old 07-13-2010, 04:22 AM   #4
Davo J
Liked 12 Times on 10 Posts
Likes Given: 4
Default Re: Cheap ball screws - your advice/experience?
Hi Simon, I would recommend them.
I bought my ball screws from them as well. The cost to buy them in Australia was $1800 plus post, linearbearings price was $640 delivered. I bought 25/5mm screw and 2 nuts per axis to load them up against each other. He does sell pre loaded nut's which have over sized balls in them, he calls them anti back lash nut's which is the way to go for single nut's.
I have inspected them and found no faults at all and they are nicely finished.
The are spoke of highly over on the CNC zone, with a lot of people using there ball screws, linear rails and also there air and water cooled high speed spindles.
Some times cheap is nasty, but in this case it's not.
Davo J is offline
Old 07-16-2010, 11:52 AM   #5
Simon0362
Thanks everyone for your advice - they are significantly cheaper than any other source for shipping into France so I was looking for the downside!
Simon
Old 07-17-2010, 08:55 AM   #6
rcfreak177
rcfreak177's Avatar
Likes Given: 70
Hi Simon,
The only downside I can see with the linear bearings ball screws may be the shorter lifespan over the more well known brands. They are made from induction hardened steel and then flash chrome plated which is only around 0.001" thick. My biggest concerns would be flaking of the hardchrome or variation in hardness. In saying that I have had no problems. Obviously most products from China do not meet ISO 9001, 9002 standards but I do believe these days products are getting better due to the highly competitive international market. I am sure at the price the ball screws in question once worn out you could throw them away and purchase new ones. Best of luck.
Barry.
Old 07-27-2010, 07:52 PM   #7
macona
Liked 5 Times on 4 Posts
I have used those screws and nuts on a torch lifter on a plasma cnc. I wouldnt use one on a cnc. They are considerably rougher than the higher quality rolled screws. These are truly bottom of the barrel screws.
I have picked up good ground screws off ebay for good prices.
macona is offline
New Member/ No experience johndaddy Introduction 10 12-01-2011 12:09 PM
A Horizontal Experience Richard Horne Photos and Videos 5 06-28-2011 10:10 PM
A Stirling Experience Richard Horne Finished Projects 9 05-14-2011 02:14 PM
Any experience or comments re SIEG KX1 CNC Metal Mickey Tools 2 08-03-2008 11:10 PM
Experience rake60 The Break Room 8 04-30-2008 02:03 AM
