Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Steady rest for Taig lathe
Old 01-16-2008, 05:22 AM   #1
joe d
Liked 53 Times on 51 Posts
Default Steady rest for Taig lathe
The factory steady for the Taig has too small a capacity for my requirements, so I had to get busy and build one with a little more room...
here are the parts after machining
after a lot of polishing, and assembly
installed on the lathe, with a piece of 1.5" aluminum just for show....
Interesting job, got to use my shiny new rotary table for the first time, looks like it will work OK.
Joe
joe d is offline
Old 01-16-2008, 05:30 AM   #2
1Kenny
Liked 12 Times on 12 Posts
Default Re: Steady rest for Taig lathe
Joe,
You did some very nice workmanship on that.
Kenny
1Kenny is offline
Old 01-16-2008, 06:01 AM   #3
Brass_Machine
Brass_Machine's Avatar
Liked 33 Times on 55 Posts
Likes Given: 3
Nice work. You should do a write up on it.
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 01-16-2008, 08:40 AM   #4
macona
Liked 5 Times on 4 Posts
Looks like a ball bearing steady? You might want to add some little slits before the bearing in its path to put some wipers in. This will keep swarf from getting sucked under the bearings and imbedding in the stock. Anything will do for scrapers. Even card stock.
macona is offline
Old 01-16-2008, 03:22 PM   #5
joe d
Macona: Good idea, wish I'd thought of it! Seems like an fast & easy mod. I'll add them before the test-drive.
Eric & Kenny: Thanks for the kind words. After looking at the project photos on this board, I had to spend the time to polish it up, the "bling" factor counts!
Joe
joe d is offline
New Steady Rest Bill Gruby Finished Projects 7 05-26-2012 02:02 PM
WTB steady rest for a Clausing or convert one? ibboatin28 Buy / Sell / Trade / eBay 2 08-01-2011 02:30 AM
Steady rest set up Captain Jerry General Engine Discussion 13 03-06-2011 03:38 AM
The right way to setup a steady rest digiex-chris Tools 9 12-12-2010 11:39 PM
Lathe Steady Rest Safety rake60 General Engine Discussion 1 01-08-2008 03:45 AM
