Project of the Month built by apointofview
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Lathe crank handle
Thread Tools Display Modes
Old 05-26-2010, 02:13 AM   #1
Chazz
Liked 2 Times on 2 Posts
Default Lathe crank handle
A couple of my mods were done before I got my camera and found this site. Anyway, one of my first projects was to make a bigger, beefier cross slide leadscrew which requires a left hand thread, so, before I even start, I wanted a hand crank for left hand threading.
It's pretty straight forward, the spindle end nut was drilled and tapped for two M6 cap screws, The crank body was tappered on the mill from scrap 1/4" thick x 1 1/2" wide mild steel flat bar and the handle end was drilled and tapped to accept one of my x/y handles from the mill (since I don't run both machines at the same time. Other than making sure it was short enough so I don't smack my hand on the access door and grinding the ends round was to paint it. Gotta look pro right? After all, when anyone looks at my mods, I want them to think they are 'stock' items.
Chazz
Yellowknife, Northwest Territories, Canada
Craftex CT039 9 x 20 Lathe & CT129N Mill
Chazz is offline
Old 05-26-2010, 07:05 AM   #2
RichD
Liked 23 Times on 21 Posts
Likes Given: 53
Default Re: Lathe crank handle
Nice crank mod Chazz!
I have the 9x20 lathe also and enjoy it very much. What is the shiny cylindrical thing by the cross slide? At first I thought you made a cross feed bearing housing, but it looks like I can still see the original aluminum housing further back.
Rich
RichD is offline
Old 05-26-2010, 01:41 PM   #3
Chazz
Nice catch Rich, it actually is the 'rough' for the new handle and bearing support for the 'Cross Slide Upgrade'. Which I hope to feature in a future post.
Thanks,
Chazz
Chazz is offline
Old 05-26-2010, 06:23 PM   #4
RichD
Likes Given: 53
Chazz,
Please post how you go about the cross slide mod when you do it. I plan to someday also and will find it helpful.
Rich
RichD is offline
Old 05-26-2010, 08:43 PM   #5
barney_leadhead
Originally Posted by Chazz
.....After all, when anyone looks at my mods, I want them to think they are 'stock' items.
You have certainly achieved that with your attention to detail - nice work
Chris
barney_leadhead is offline
Old 01-15-2011, 10:46 AM   #6
Lockstocknbarrel
Lockstocknbarrel's Avatar
Liked 21 Times on 13 Posts
Hi Chazz,
Nice job yes it looks factory, just a thought why not open up the centre then you can still run a long shaft through the whole setup, sorry just a small idea.
Very professional.
Kindest Regards
Dave Weir.............(Beagles)
Lockstocknbarrel is offline
Another tap handle ghart3 Tools 6 01-09-2010 03:49 PM
Leadscrew Handle SKIPRAT Machine Modifications 5 11-22-2009 10:17 PM
Tap Handle JimN Tools 12 09-11-2009 06:29 AM
A crank for a cranky old man's lathe mklotz Tools 19 07-02-2009 02:11 AM
Hand Crank for the Lathe Spindle BillH Safety 11 02-28-2009 03:42 AM
