Project of the Month built by dnalot
Home Model Engine Machinist > The Tools and Tips > Tools > 8" Mini Shear Brake
Old 04-25-2010, 01:33 PM   #1
BMyers
Liked 9 Times on 9 Posts
Default 8" Mini Shear Brake
I want a shear and brake to fabricate the cab for my Cracker Locomotive. Does anyone have
the mini 8" shear brake that HF, Grizzly and a few others sell ? I would like some feedback.
My use is mostly copper and brass.
BMyers is offline
Old 04-25-2010, 09:08 PM   #2
Tin Falcon
Tin Falcon's Avatar
Liked 809 Times on 646 Posts
Likes Given: 18
Default Re: 8" Mini Shear Brake
I have the slightly larger cousin.
I have not really used it much. Should do more with it. I did take it apart clean debur and lubricate. These are typical of the import machine a solid machine but fit and finish need help. also in my experience you need to put a radius on the bending leaves. A sharp edge will put grooves in the metal that are stress points and cause cracking . I was trained in aircraft sheet metal. a small radius is ok but never a sharp bend . IIRC the edges on the leaves are shipped pretty sharp and with burs.
just a couple of observations, both machines rated at 22ga steel so a bit thicker with copper.
the 7 1/2 inch machine is 27 lbs and cost almost $200
the 12" is 114 lbs for 260$ plus you get the slip roller
I picked mine up at the Grizzly show room a few years back, when it was on sale, so saved on shipping . IIRC looking at the two side by side I felt that the 12" 3 in one was a better value .
I have heard that the 30" units have a bit too much flex.
Hope this helps.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 04-25-2010, 09:21 PM   #3
BMyers
that looks like a nicer machine.
BMyers is offline
Old 05-01-2010, 02:37 AM   #4
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
a little more discussion here.
http://bbs.homeshopmachinist.net/showthread.php?t=32469
52" shear clean up Ed T Tools 3 06-10-2012 10:34 PM
Enco 12" Shear 1hand Tools 1 03-05-2011 03:19 AM
4 "or 6"rotary table for mini mill carl86 General Engine Discussion 9 02-01-2011 05:53 PM
Brake/Shear don-tucker Tools 3 12-09-2009 11:59 PM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex General Engine Discussion 11 06-11-2009 01:19 PM
