Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Plans > homemade vertical milling machine
Old 04-21-2010, 06:00 PM   #1
johnthomp
Guest
Posts: n/a
Default homemade vertical milling machine
hello out there can anyone help me with a serious dilema i have finally killed my converted pillar drill milling machine by dropping it while moveing workshops its totaled and nothing exept the spindle bearings and the chuck are salvageable so ive decided to build my own useing a half horsepower reversible single phase motor i have had under the counter for years and an x/y table i can ressurect from the ill do something with that someday cabinet has anyone got any ideas or plans for any kind of headstock i can use for this devise as i have loads of I section gurders from my previous occupation as a builder and a fair few feet of 2 1/2" steel pipe lying around the place i found in the local scrap yard i have no choice but to build a new miller because ive been made unemployable due to a bad work accident and therefore i have no money so does anyone fancy egging me on while i undertake one hell of a scrapheap challenge
Old 04-21-2010, 07:29 PM   #2
kcmillin
Liked 82 Times on 78 Posts
Default Re: homemade vertical milling machine
I cant help you with plans for a head. But I will be intertested in seeing it come along.
Kel
Machinists do it with precision.
www.burleighmachine.com
kcmillin is offline
Old 04-21-2010, 08:18 PM   #3
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Hi John, I am sorry to hear of your troubles. It seems to me I remember reading an article and seeing actual photographs of a mill that was devised from the 'junk' recycle pile and a discarded engine block. Maybe if you perform a google search you will run across the article. It included drawings etc. It appeared as an odd looking contraption but it seemed to function quite well in it's role as a milling device.
BC1
Jim
bearcar1 is offline
Old 04-21-2010, 09:53 PM   #4
johnthomp
Guest
Posts: n/a
Kel
soon as i figure out how to get fotos uploaded onto this site ill start posting them ive already started with the rear stem and base with the gurders and working on some way of makeing a carriage or slider to wind along what i call the up and down axis i would call it x/y or z but algebra isnt one of my strong points as ive never heared the word hypotenues over the dinner table haa haa watch this space
Old 04-21-2010, 10:00 PM   #5
johnthomp
Guest
Posts: n/a
BC1
Jim
ive seen something similar to what you described on youtube but it was removed after some safety nut reported the fella for putting the machine online it ran outside only due to the main guts of it being a briggs and stratton mower engine with a chuck straight on its pto shaft going at 7000rpm theres another video on there you might be interested in its a polish fella thats made a 15ft woodturning lathe out of junk for turning 12" square beam supports looks pretty bloody scary but verry high quality craftmanship watch this space for the progress fotos
Old 04-23-2010, 08:06 PM   #6
johnthomp
Guest
Posts: n/a
part 1
i started by welding two pieces of gurder together at 90 degrees to create what can only be described as a giant square i then wrapped the longer section with angle iron offcuts to create a snug fitting box section slider (only because i didnt have any box section suitable to my purpouses at the time)
in the back of the box section i welded a 10mm nut to act as a stay for my 10mm threaded bar winder shaft then fixed either end of the threaded bar to either end of the gurder with yet more angle iron offcuts giveing me one hell of a solid stand and travel with a winder that seems to be more than solid enough for my purpouses
http://i107.photobucket.com/albums/m310/amd47/SDC16395.jpg[/img]]
Old 04-23-2010, 08:25 PM   #7
johnthomp
Guest
Posts: n/a
part 2
after a restless grinding the gears in my head i came up with an idea for a headstock
for this i used a chunk of gurder again with a length of 2" internal bore steam pipe housed on the end keeping it all as square as possible and as i have no milling machine at the moment i had to butcher the pipe into the end of the steel useing a 7mm drill bit in my hammer drill and a 4" angle grinder and while tacking it together with the ark welder a few fine adjustments with the large battering stick i used the 2" pipe because it sort of fits the two bearings i pulled of an old pump pallet truck wich have a 1" inner bore perfect for the spindle i thinkhttp://i107.photobucket.com/albums/m310/amd47/SDC16397.jpg[/img]]
Old 04-23-2010, 08:38 PM   #8
johnthomp
Guest
Posts: n/a
part 3
ive been at it with some of the gubbins for this contraption ive made the spindle out of 1 1/4" steel bar i dont know what type of steel but it started life as a half drive shaft off a car if its strong enough to do that its strong enough to do this and it was begging to be used anyway
i then installed it in the red tube on the headstock shell with the two big ass bearings off the pumptruck and press fitted them into the steel bearers i made for them so i could weld them in when ive got it running true down the pipe
once i was happy with the resulting lump i then welded it to the slider i put on the post the day before and to all intents and purpouses so far it dont look too bad for a pile of junk ive even shocked myself with this one it all runs free true and has literaly no play in it anywhere (not bad for the 19 hours metal bashing spent so far ) http://i107.photobucket.com/albums/m310/amd47/SDC16398.jpg[/img]]
Old 04-23-2010, 08:44 PM   #9
johnthomp
Guest
Posts: n/a
Kel
ive got some pics and illustrations up here now and its comeing on a little now but please keep an open mind as its made from scrap iron and salvaged parts and as yet hasnt cost me a penny
Old 04-24-2010, 12:10 AM   #10
kcmillin
Looks like a good and sturdy column and head to me.
Nice work John.
Kel
kcmillin is offline
Contemplating Grizzly's Horizontal/Vertical milling machine willburrrr2003 The Break Room 19 11-20-2015 03:54 PM
Milling machine or vertical slide for the lathe, which should I buy? Kaleb General Engine Discussion 27 10-16-2011 09:56 AM
Emco Vertical Milling Attachment steamtoys Buy / Sell / Trade / eBay 0 12-25-2010 07:31 PM
Hurco VMC vertical mill/mills/milling paulmars Buy / Sell / Trade / eBay 0 01-27-2010 09:55 PM
bridgeport manual vertical mill milling machine w/rotary table,vise,angle head, paulmars Buy / Sell / Trade / eBay 2 01-01-2010 03:59 PM
