Home Model Engine Machinist > Building Them > General Engine Discussion > Sharpening Carbide Bits
Old 04-21-2010, 01:23 AM   #1
IronHorse
IronHorse's Avatar
Liked 31 Times on 18 Posts
Default Sharpening Carbide Bits
I picked up a "green" wheel for my grinder. I want to resharpen some of my Carbide tipped lathe bits. My question is, do you "dip" these type of bits in water like you do for HSS or let them air cool?
Ironhorse
IronHorse is offline
Old 04-21-2010, 02:06 AM   #2
tup48
Liked 2 Times on 2 Posts
Default Re: Sharpening Carbide Bits
Hi Ironhorse;
When I sharpen my Carbide bits the first thing I do is to grind the under side with a regular wheel and then grind the carbide with the green wheel.
Yes I always dip the tool in water (not to cold).
A good rule is to hold the tool close to the end being ground and when your fingers start to get hot it is time to dip in water.
Richard
Richard
Northern New York USA
Passed Away 9-30-13
tup48 is offline
Old 04-21-2010, 03:32 AM   #3
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
Are you are referring to brazed carbide bits, such as this turning tool and boring bar
from my tool box?
If that is the case you HAVE to keep them cool!
Heat from grinding build up quicker than we would expect.
That heat can become high enough to weaken the brazed bond between the
carbide and the tool.
Grind a little and quench it, grind a little and quench it...
If you are referring to solid carbide tools, grind them until you are happy with
the result and let them air cool.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 04-21-2010, 05:19 AM   #4
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
IH,
This is very basic stuff, but a reminder in case anyone doesn't know about it.
When grinding carbide tools, either by hand or machine, you only ever grind up or down on the cutting faces, NEVER across.
If you grind or lap across the face, you will find that the carbide will de-laminate and chip very easily when cutting.
Bogs
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 04-21-2010, 12:44 PM   #5
IronHorse
IronHorse's Avatar
thanks guys for the info.
IronHorse
Old 10-24-2010, 08:51 PM   #6
davisdesigns
If you don’t like the hassle and mess of a green wheel you could try this.
https://sites.google.com/site/davisd...b/Products/dch
davisdesigns is offline
Old 10-24-2010, 10:41 PM   #7
Brian Rupnow
Liked 4125 Times on 3271 Posts
Likes Given: 37
A very timely thread. I bought a green wheel last week to sharpen my carbides, and haven't used it yet.----Brian
Brian Rupnow
Brian Rupnow is offline
Old 10-25-2010, 12:00 AM   #8
davisdesigns
Originally Posted by Pat J
I found this PDF a while back on this site, and it mentions the hazards of breathing carbide dust.
Be careful about the fumes, vapors, dust, etc. in a confined shop area.
You never know if or how that stuff will affect you.
It may affect some and not others, but it is not worth the gamble.
Protect yourself, don't risk it.
Pat J
I think just about everything we do now days is bad for us.. The grinding wheel it's self is hazardous to breath, maybe all these years of grinding with an aluminum oxide wheel has given me alzheimer's. I forget things often..
PS sorry about the above post I put it in the for sale section, I was warned…
Old 10-25-2010, 02:51 PM   #9
Ned Ludd
Liked 4 Times on 4 Posts
Hi Guys,
I seem to recall that one should not quench carbide when grinding, for the same reason that you should either use flood cooling or none at all when turning with carbide tools to prevent cracking. Am I wrong, again?
Ned
Ned Ludd is offline
Old 10-25-2010, 05:10 PM   #10
doc1955
Gone
Liked 53 Times on 52 Posts
Likes Given: 22
Originally Posted by Ned Ludd
Hi Guys,
Ned
You are correct you can cause premature failure even if you don't see the cracks in the carbide. The best thing is to cool with just an air gun cracks will form from thermal shock otherwise.
Gone!
doc1955 is offline
Simple brazed carbide tool sharpening Deanofid Tips and Tricks 13 02-22-2011 01:41 AM
Need tips about sharpening carbide cutters. jpeter General Engine Discussion 4 12-25-2010 01:57 AM
Sharpening mill bits wes Tips and Tricks 6 02-20-2010 04:24 AM
Carbide bits/end mills and lubrication ChooChooMike Tips and Tricks 10 01-30-2010 01:49 PM
sharpening small drill bits gilessim General Engine Discussion 9 01-30-2008 04:23 PM
