Home Model Engine Machinist > The Tools and Tips > The Shop > Home made jib crane with photos
Old 02-24-2010, 05:29 AM   #1
Davo J
Liked 12 Times on 10 Posts
Likes Given: 4
Default Home made jib crane with photos
Hi, I hope this is the right section to put this in.
I posted it else where as well but thought the members here be interested.
I have been having a hard time lifting things on and off the mill and the lathe for some time and usually had to get a hand off someone (usually my son) to give me a lift. The problem is not age but a broken disc in my neck and after a MI scan and surgery (the operation was unsuccessful) the doctors told me I had an 80 year old spine at the ripe old age of 38 that was 4 years ago. About 12 months ago I had the son in-law help lift the 250mm (10) rotary and he nearly dropped it, so I decided to build a crane to do the lifting as I still wanted to lift things on my own but safely.
After some research on the internet (not much out there) I built this jib crane last year but only put it up at Christmas. It was made of scrap that I picked up in a dumpster and the main post a mate gave to me.
The beam is 150mm x 75 (6"x3") and is 2.3 mtrs (7.5ft) long made up of 2 pieces welded together. The vertical leg is 1mtr (3.2ft) long.
The bearings retainers are from the rear diff of a Nissan 720 4x4 pickup with a standard 30mm inner bearing in the top retainer and the bottom one with the original taper bearing from the axle. There is a 40mm (13/4) square trailer axle machined at both ends to suit the bearings welded to the back of the crane. I made plates up to go around them and welded them to the crane as extra insurance.
I made the brackets up to hold the bearing retainers out of 10mm (3/8") plate and they bolt onto the 100x100mm (4"x4") thick wall post. They bolt on to the post with 4 x 20mm (3/4) HT bolts top and bottom. I welded the nuts to a 300mm x 90 x 6mm ((1x 3 1/2x1/4) plates top and bottom and then slid the plates inside the post while it was laying on the ground. A couple of small countersunk bolts hold them in place until the post goes up and the bolts go in. The top plates are 150 x 150x 10mm (6x6x3/ with the same 20mm bolts and the bottom plate is 300x175x20mm (1x7x3/4) with 5x 16mm (5/ pins into the concrete. I made the dummy bolts at the bottom because it has to be removed to another location latter. They have a hex head but no thread and are hammered 75mm (3)into the tight fitting hole in the concrete.
You will see in the photo that I made up some temporary angle brackets with thread bar to do the final adjustments to the post when the crane was up, before welding the bottom. I was lucky I did that as when I first put it up it needed to go higher than I thought. So I lifted it 150mm higher and had to redrill more holes and plug up the old ones.
The beam trolley is made up to suit the electric winch my wife bought me for a Christmas present. I had an old beam trolley that I got the wheels off.
Just after getting it up I decided I needed a cable festoon for the electric wires so I found a deal on eBay plastic wheels and made some trolleys up out of 3mm (1/8) plate.
I made it so the controller is separate from the winch and left provision for the power controls that I will be fitting latter to move it in and out and side to side.
I havent used it much as I am doing renovations on the house but it will be a big help in the future.
All up it only cost me $25Aus dollars and that was for the stickers and the festoon wheels.
This is the first time I have put together a post so I hope I havent left anything out and I hope its understandable.
Davo
IM000201 (Large).jpg   picture7 394 (Large).jpg   IM000196 (Large).jpg   IM000197 (Large).jpg
Davo J is offline
Old 02-24-2010, 05:31 AM   #2
Davo J
Likes Given: 4
Default Re: Home made jib crane with photos
Some more
picture7 391 (Large).jpg   picture7 392 (Large).jpg   IM000207 (Large).jpg   IM000208 (Large).jpg
Davo J is offline
Old 02-24-2010, 05:33 AM   #3
Davo J
Likes Given: 4
Some more
IM000206 (Large).jpg   IM000210 (Large).jpg   IM000211 (Large).jpg   picture7 397 (Large).jpg
Davo J is offline
Old 02-24-2010, 05:35 AM   #4
Davo J
Likes Given: 4
And last.
Davo
picture7 395 (Large).jpg   picture7 423 (Large).jpg   picture7 425 (Large).jpg   picture7 429 (Large).jpg
Davo J is offline
Old 02-24-2010, 06:24 AM   #5
BigBore
Liked 14 Times on 14 Posts
Very inventive. I'm going to need something like this myself in the not too distant future. Do you have plans on lifting anything that approaches your 500 Kilo capacity?
Ed
Ed
Some people are like Slinkys... Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
BigBore is offline
Old 02-24-2010, 06:55 AM   #6
Davo J
Likes Given: 4
Hi Ed,
I will only be lifting about a 100kg with the rotary table, mounting plate and chuck,
but thought I would rate it at 500kg like the hoist. It is capable of more but I wont be lifting that much. Also I doubt the Chinese hoist would lift 500kg anyway. I would need to put my manual chain block on for that sort of weight.
Any heavy lifting is done off the shed trusses. My father in-law, who has passed now, was a chief draftsman at the mines and designed them to be capable of lifting 3 tons.
One tip is when building a crane like this is, you have to allow for flex. Instead of the crane being square it's opened up about 5mm in 2400mm too allow for the flex when loaded as it will bring it down to be level. I picked that one up off one of the manufactures web sites.
Davo
Davo J is offline
Old 02-24-2010, 06:57 AM   #7
BigBore
Good stuff. Thanks.
Ed
BigBore is offline
Old 02-25-2010, 03:19 AM   #8
shred
Liked 34 Times on 34 Posts
Cool. Looks good to me. I've been noodling with crane ideas for a while, and you're right there's not much out there.
With a weak ceiling that limits my options as does the massively cluttered shop (it takes much cleaning just to get the engine hoist out), I'm thinking some sort of cart-with-a-crane that can pick up ~150 lbs off a machine and deposit it onto the cart is what I want. The Skyhook people make something like that' but it's pretty large $, and as yet nobody's put a patient lift on craisglist for a reasonable price (there was a HSM article not too long ago about converting one to a hoist) nearby I think I'll end up fabbing something myself as well.
shred is offline
Old 02-25-2010, 07:53 AM   #9
Davo J
Likes Given: 4
Shred,
Have you seen this one? It seems he had the same situation as you have with the ceiling.
http://images.google.com.au/imgres?i...26tbs%3Disch:1
Davo
Davo J is offline
Old 02-26-2010, 02:06 AM   #10
shred
Thanks I saw that one, but I don't want to put any weight on the ceiling or rafters, so an overhead is pretty much out of the question without major re-beaming of the garage (the roof sags just due to the weight of the drywall .. I suspect they may have been smoking something in 1968 when they built the place). A floor-standing gantry or jib would work, but wouldn't cover all the area and take up a lot of room. Since I have a 2-ton engine hoist, I'm thinking a little version to run around and move a less than a tenth of the weight around would do nicely.
Something vaguely like this I think:
shred is offline
what home made machines have you made? New_Guy Tools 36 12-13-2012 03:47 PM
Home made EDM. Arnak The Break Room 5 05-10-2012 11:48 PM
Home Made Bandsaw kustomkb Tools 7 08-16-2010 07:37 PM
Home made Pyrometer Powder keg Engines From Castings 8 07-14-2008 04:35 AM
Home-made CNC router DICKEYBIRD Photos and Videos 10 12-23-2007 03:25 PM
