Project of the Month built by driller1432
Home Model Engine Machinist > The Tools and Tips > Tools > homemade machines?
Old 02-15-2010, 11:09 PM   #11
kcmillin
Liked 82 Times on 78 Posts
Default Re: homemade machines?
I find nothing more satisfying than using a tool wich you made. I often look for projects to do, and there are plenty of tools on that list. Ive made countless saw blades for use on alumoinum, wood, and brass. Homemade flycutters, and other tool bit holders for the lath and mill.
Here are a couple I use all the time.
This is based on a hand vice I seen in a catalog. I used walnut for the handle. I also made four of them and gave them away as presents. Cant find these at the hardware store.
Here is a 3 inch milling vice I made out of a big chunk of steel. It is verry handy when a small vice is needed.
kel
Machinists do it with precision.
www.burleighmachine.com
kcmillin is offline
Old 02-16-2010, 12:58 AM   #12
New_Guy
Liked 10 Times on 10 Posts
......i suppose im the only crazy one on here who wants to build working machine tools :P
ill keep my mouth shut so you guys dont see the seriousness of my condition
New_Guy is offline
wyleecoyote Likes This
Old 02-16-2010, 01:08 AM   #13
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Lorenz:
Yes miniature tool building certainly is a branch or sub division of model engineering or engineering in miniature. There are several vendors that offer kits of mini machine tools as others have mentioned. I do not recall many plan sets available I think most folks copy a machine they have. As our banner states this site is dedicated to model engines from bar stock. This does not mean you can not post builds of model machines . We would love to see such posts and they will be encouraged. You may not get a lot of help simply because this is not the forums area of expertise.
Tin .
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 02-16-2010, 01:52 AM   #14
DavesWimshurst
DavesWimshurst
Liked 9 Times on 9 Posts
Lorenz,
Metal and wood cutting band saw 17.5 inch wheels, speeds from 115 to 3350 feet per minute using belt changes and gear speed reducer:
belt sander:
This machine uses 1" x 42" belts.
PM Research lathe and drill press
DavesWimshurst is offline
Old 02-16-2010, 03:21 AM   #15
kuhncw
Liked 61 Times on 59 Posts
Likes Given: 9
Dave, nice job on the home built machines. What did you use for the 17.5 inch wheels on your bandsaw?
I've not yet built any complete machines, but I am working toward converting a Taig lathe to CNC.
Thanks for the post. Home built machines are always interesting to me.
Regeards,
Chuck
kuhncw is offline
Old 02-16-2010, 04:08 AM   #16
E Chris
Liked 2 Times on 2 Posts
Hi Lorenz,
There seems to be some of us out there that do enjoy making small machine tools.
Some are more interested in form, others, function. The English author, L.C. Mason wrote a fine book called "Building a Small Lathe". Anyone considering to build a small lathe would find this book very useful. A person that combined form and function to a very high degree is Bill Huxhold. Mr. Huxhold's model of a Hardinge lathe is in all probability just as fine as the prototype.
I have recently made a small swing-type tool and cutter grinder. It has the capability of having either a horizontal (shown) or vertical spindle. As you can see I am definitely in the function, not form, camp.
Chris
E Chris is offline
Old 02-16-2010, 04:17 AM   #17
New_Guy
wow Chris thats just amazing!!
New_Guy is offline
Old 02-16-2010, 05:39 AM   #18
bentprop
Liked 17 Times on 17 Posts
As far as powered machines go,I made a 6" disk sander using the motor out of a factory extractor fan.Uses a mdf disk as backing.It's a bit of a pain having to scrape of the glue when changing a disk,but I don't do it very often now.
I also made a small circular saw,using a motor out of an old drill press.The blade was a 2" Minicraft blade,that had been in a drawer for at least 10 years!
When I think of it,I'll take a few pics.
Chris,that's a nice piece of workmanship,care to tell a bit more about it?I don't really see how it works.
Hans.
bentprop is offline
Old 02-16-2010, 06:12 AM   #19
1hand
Liked 49 Times on 46 Posts
Likes Given: 5
I'm with Bentprop, I also interrested in how that works Chris.
Matt
1hand is offline
Old 02-16-2010, 03:41 PM   #20
E Chris
Hello everyone,
Thanks for the kind remarks. I believe they call this type a swing grinder and indeed it does. The column and of course the head/motor are free to swing from side to side and to rise and fall. There is a ball bearing at the bottom of the column that acts as a thrust bearing and at the top there is an fine (40 tpi) elevating screw that has about a half inch travel. The 40 tpi and large graduated hand wheel gives sub-thousandth height control. The coarse screw towards the back is for rough height adjustment and is locked by the know on the side of the arm. As I mentioned in an earlier post the horizontal spindle assembly can be replaced with a vertical spindle for using cup wheels. The vertical spindle will do double duty when I finish the Quorn grinder. My son calls this a tin can grinder because of my use of a can to make the dust shield for the column. The base plate and indeed the column base are surplus mainframe computer tape parts. And I didn't think computers were of any use!
I will try and attach a photo of a drawing and hope it will help.
I will be glad to answer any other questions.
Chris
E Chris is offline
Homemade cutting oil??? Mastermaker Tools 43 09-28-2013 11:47 AM
homemade scriber mzetati Tools 6 06-14-2011 02:48 PM
Homemade DRO...maybe...sort of... zeeprogrammer Machine Modifications 129 07-05-2010 01:25 AM
Homemade DRO questions compressor man General Engine Discussion 5 03-13-2010 12:01 PM
Homemade CNC Kermit The Break Room 0 09-27-2009 02:32 PM
