Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Sieg SX4 Vertical Mill
Old 02-02-2010, 01:53 PM   #1
Omnimill
Liked 53 Times on 47 Posts
Likes Given: 44
Default Sieg SX4 Vertical Mill
This looks pretty good: http://www.siegind.com/product.php?id=78
I'm wondering how much they will go for in the UK?
Vic.
Omnimill is offline
Old 02-02-2010, 02:11 PM   #2
JimM
Liked 4 Times on 4 Posts
Default Re: Sieg SX4 Vertical Mill
Vic.
Take the price they sell for everywhere else in the world, double it, stick another zero at the end and you'll probably won't be too far off
Bloomin rip off Britain
JimM is offline
Old 02-02-2010, 10:25 PM   #3
Omnimill
Likes Given: 44
Sadly, you're probably right Jim
Omnimill is offline
Old 02-02-2010, 10:34 PM   #4
CrewCab
Liked 32 Times on 32 Posts
Specs wise they seem to be in the same "ball park" as Chester's 626 and Super Lux, ......... probably better than the Super Lux in fact ............ so I would suspect cost will be around 2k (and probably plus a bit) .........
CC
CrewCab is offline
Old 02-06-2010, 03:19 PM   #5
gunboatbay
Liked 11 Times on 11 Posts
FYO - Because of all the work they've done with the X3 & SX3 mills, when I first saw the descriptions of the X4/SX4, I queried Arceurotrade (Ketan), to see if they planned on testing/marketing the X4. No, he indicated that the machine was larger than they were interested in.
gunboatbay is offline
Old 02-08-2010, 10:50 PM   #6
Omnimill
Likes Given: 44
Thanks for that, worth knowing.
Vic.
Omnimill is offline
Old 01-04-2011, 07:55 PM   #7
techonehundred
Liked 14 Times on 12 Posts
On the west side of the pond, the X4 is now available from Mr. Grizz. So it should help you with the price.
http://www.grizzly.com/products/Heav...-Machine/G0720
Just remember wherever you go, there you are!
techonehundred is offline
Old 01-05-2011, 04:50 AM   #8
jim216
Liked 2 Times on 2 Posts
Spindle taper MT4 I hope that's a misprint, unless I'm missing something.
http://www.grizzly.com/catalog/2011/Main/547
jim216 is offline
Old 01-05-2011, 05:46 AM   #9
Bolster
In the Machine Data Sheet it says "Spindle Taper....R8"
600 lbs? That's RF-45 territory isn't it?
Just under $3K....hm, that's 3x the price of an X3, which is just under a 400 lb machine. Motorized Z axis nice, probably too heavy to crank by hand. I'd kill for that additional Y travel, but it has less Z travel than an X3. That tilt angle display looks like someone stuck in an off-the-shelf digital angle gauge in there.
Bona Fide Soggy Bottom Boy
Bolster is offline
Old 01-05-2011, 12:13 PM   #10
Cedge
Cedge's Avatar
Liked 60 Times on 59 Posts
I predict we'll see a few Sx3's being modded to add the head lift motor and now I know here my digital protractor is supposed to be stored....LOL. A bit pricey for my pocket.
Steve
Cedge is offline
Sieg C2 300 Lathe with mill add on? MadKad Machine Modifications 7 12-12-2012 09:15 AM
Sieg X2/X3 mill recommendations lazylathe Tools 18 01-15-2012 01:47 AM
Tramming Problem with Sieg X2 Mill excalibus General Engine Discussion 2 09-20-2011 06:52 PM
Sieg X2 Mill? and lathe? lazylathe Tools 22 02-18-2011 06:37 PM
Sieg Super X1 Mini-mill Julian Machine Modifications 4 04-28-2008 06:50 PM
