Project of the Month built by driller1432
Home Model Engine Machinist > The Tools and Tips > Tools > Z axis DRO from digital caliper
Old 01-23-2010, 08:09 PM   #1
radfordc
Liked 32 Times on 22 Posts
Default Z axis DRO from digital caliper
I bought a cheap digital caliper and mounted it to my mill to use as a z axis readout.
radfordc is offline
Old 01-23-2010, 08:11 PM   #2
radfordc
Default Re: Z axis DRO from digital caliper
The good thing about this cheap caliper is that the jaws aren't hardened. I was able to drill mounting holes with no problem.
radfordc is offline
Old 01-23-2010, 08:13 PM   #3
radfordc
Since the caliper is only 6" long I used a steel rod and some thumb screws to give it full range.
Charlie
radfordc is offline
Old 01-23-2010, 08:43 PM   #4
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
Very cool. I need to order up a dozen or so of these digital calipers.
Chuck
cfellows is offline
Old 01-23-2010, 08:53 PM   #5
rudydubya
rudydubya's Avatar
Liked 25 Times on 24 Posts
Nicely done Charlie. Thanks for sharing. Did you cut the jaws shorter or are they still full length?
Rudy
rudydubya is offline
Old 01-23-2010, 10:53 PM   #6
radfordc
I cut the tips of the jaws off where they join the flat part.
radfordc is offline
Old 01-24-2010, 03:55 AM   #7
black85vette
Liked 60 Times on 57 Posts
Nice adaptation to put the display on the rod and thumb screw to extend the range. Very innovative.
black85vette is offline
Digital Caliper to Height Gauge ozzie46 A Work In Progress 20 03-27-2014 09:00 PM
Instant Y axis Caliper DRO Lesmo A Work In Progress 3 06-06-2011 08:21 PM
Digital Caliper batteries Tin Falcon Tools 52 02-08-2011 08:10 AM
Digital Caliper guage max corrigan The Break Room 0 12-08-2010 08:29 PM
digital caliper calculator Ed T Tips and Tricks 20 06-02-2010 06:14 PM
